So please excuse the little doodle was the best way I could think of making myself clear, then blue squares are the lithium ion 4.2 v batteries I have linked in series, now I have a charged that should* be able to charge 20/21v at somewhere around 2Ah, however I am running into a heat problem, the little dots I have drawn in the middle of the "cells" indicate their temperature to the touch after about 10-20 minutes of charge. I am wondering if this could be a problem with the particular cell, the size/resistance of the connecting wires, the charger being incompatible (there is virtually no information on it) or another option I have overlooked in my inexperienced clumsy eagerness. I have disconnected everything to be safe and would like to know the safest way to proceed and test from here. Much appreciated.
  • 4
    \$\begingroup\$ How are you balancing the cells? \$\endgroup\$ – Brian Drummond Dec 19 '17 at 19:16
  • \$\begingroup\$ read the voltage on each cell and report the 5 results back here \$\endgroup\$ – Neil_UK Dec 19 '17 at 21:35
  • \$\begingroup\$ 4.49, 4.31, 4.31, 4.21, 4.32 are the voltages on each cell, from positive terminal to negative terminal. I am not exactly sure, I did not know how or if I needed to balance them with the charger. \$\endgroup\$ – Kieran Davies Dec 19 '17 at 22:32
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
