I tried to implement the simple FIFO and its test bench.
FIFO testbench code:
`timescale 1ns / 1ps
module fifo_tb();
  localparam B=4, W=2; //4bit sized 4 entry fifo
  localparam T=20;
  reg clk, reset;
  reg rd, wr;
  reg [B-1:0] w_data;
  wire [B-1:0] r_data;
  wire empty, full;
  fifo fifo
  (.clk(clk), .reset(reset), .rd(rd), .wr(wr),
   .w_data(w_data), .empty(empty), .full(full),
   .r_data(r_data));
  always begin
    clk = 1'b1;
    #(T/2);
    clk = 1'b0;
    #(T/2);
  end
  initial begin
    reset = 1'b1;
    #(T/2);
    reset = 1'b0;
  end
  initial begin
    wr = 1;
    rd = 0;
    w_data = {B{'b1000}};
    @(negedge reset);
    @(negedge clk);
    w_data = {B{'b0100}};
    @(negedge clk);
    w_data = {B{'b0010}};
    @(negedge clk);
    w_data = {B{'b0001}};
    @(negedge clk);
    $stop;
  end
endmodule
FIFO module code:
module fifo
  parameter B=8, // number of bits in a word
            W=4 // number of address bits
  input wire clk, reset,
  input wire rd, wr,
  input wire [B-1:0] w_data,
  output wire empty, full,
  output wire [B-1:0] r_data
  reg [B-1:0] array_reg [2**W-1:0];
  reg [W-1:0] w_ptr_reg, w_ptr_next, w_ptr_succ; //tail
  reg [W-1:0] r_ptr_reg, r_ptr_next, r_ptr_succ; //head
  reg full_reg, empty_reg, full_next, empty_next;
  wire wr_en;
  //register file write operation
  always @(posedge clk)
    if (wr_en)
      array_reg[w_ptr_reg] <= w_data;
  //register file read operation
  assign r_data = array_reg[r_ptr_reg];
  //write enabled only when FIFO is not full
  assign wr_en = wr & ~full_reg;
  //fifo control logic
  //register for read and write pointers
  always @(posedge clk, posedge reset)
    if (reset)
      begin
        w_ptr_reg <= 0;
        r_ptr_reg <= 0;
        full_reg  <= 1'b0;
        empty_reg <= 1'b1;
      end
    else
      begin
        w_ptr_reg <= w_ptr_next;
        r_ptr_reg <= r_ptr_next;
        full_reg  <= full_next;
        empty_reg <= empty_next;
      end
  //next state logic for read and write pointers.
  always @*
    begin
      //successive pointer values
      w_ptr_succ = w_ptr_reg + 1;
      r_ptr_succ = r_ptr_reg + 1;
      //default: keep old values.
      w_ptr_next = w_ptr_reg;
      r_ptr_next = r_ptr_reg;
      full_next  = full_reg;
      empty_next = empty_reg;
      case ({wr, rd})
        // 2'b00 no op
        2'b01: //read
          if (~empty_reg) // not empty
            begin
              r_ptr_next = r_ptr_succ;
              full_next = 1'b0;
              if (r_ptr_succ == w_ptr_reg)
                empty_next = 1'b1;
            end
        2'b10: //write
          if (~full_reg) // not full
            begin
              w_ptr_next = w_ptr_succ;
              empty_next = 1'b0;
              if (w_ptr_succ == r_ptr_reg)
                full_next = 1'b1;
            end
        2'b11: //write and read
          begin
          end
      endcase
    end
  //output
    assign full  = full_reg;
    assign empty = empty_reg;
endmodule
As far as I know putting @(negedge clk); makes the code infornt of it
to be executed at the negative edge of the clock, and
putting @(negedege clk); @(negedge clear); back to back makes the code to be executed at the negatvie edge of the clock that generated after the clear becomes zero.
Therefore, I've expected that the first code block in initial block
    wr = 1;
    rd = 0;
    @(negedge reset);
    @(negedge clk);
will be executed after the reset <= 0 and clk <=0 (i.e., 30ns in the below simulation).
However, the simulation result shows that the wr, rd, w_data are set at the first rising edge of the clock not at the 30ns. What code block generated this unintended simulation result?
I've tried to debug it, but still having a hard to find it...
I appreciate any help.
I would start with keeping the reset with the reset of your test code, thus not in an apart initial statement. Your problems starts with:
@(negedge reset);
@(negedge clk);
That is a race condition as your reset and clock have the same timing delay: "#(T/2);". It never hurts to have your reset active a bit longer (e.g. you could have somebody else's module which has a synchronous reset). My test benches all look like:
localparam CLK_PERIOD=100;
initial
begin
   reset_n   = 1'b0;
   #(CLK_PERIOD*10) ;
   reset_n = 1'b1;
   #(CLK_PERIOD*4) ;
   // This is where the testing starts
   @(posedge clk)
I own a website which gives complete free Verilog code with the testbenches and it has NO advertising, but I don't know the exact rules of stackexchange so I can't point you there.
    \$\begingroup\$ A link to additional information is fine as long as you've answered the basic question here. However, make sure that the linked page is directly relevant to the question. \$\endgroup\$
    – Dave Tweed
    Dec 20, 2017 at 12:33
