I am trying to get -13.5V from mc34063.
On the first design, I used 8DIP package MDR34063AP and no problem getting -13.5V.
On the second design changed the package to 8-soic and used S1B-13F (100V 1A diode), which are replacements with same characteristics.
However, after 2 seconds IC starts to consume more and more current gets hot and burns.
When I increased the R22=1R resistor to 2.5R, it doesn't overheat but I can't get -13.5V anymore. It stays around -9V.
Any comment or help would be really useful,
Thank you for your time.
Design 1
Design 2 enter image description here
  • \$\begingroup\$ On second design, D7 is elsewhere. Not missing. \$\endgroup\$ – Alian4life Dec 21 '17 at 1:44
    \$\begingroup\$ S1B-13F, 1N400x are inappropriate for SMPS designs- too long recovery time even for a pig of a chip like 34063- and not even specified. Use a Schottky diode like the datasheet shows. Is the inductor the same in both cases? \$\endgroup\$ – Spehro Pefhany Dec 21 '17 at 3:42
  • \$\begingroup\$ have a close look at the chip. there may have been a mixup with part numbers \$\endgroup\$ – jsotola Dec 21 '17 at 3:43
    \$\begingroup\$ @SpehroPefhany Thank you so much Spehro, switching to Schottky solved the issue! Thank you for your help, sending you all the good karma! \$\endgroup\$ – Alian4life Dec 21 '17 at 4:43
1B-13F, 1N400x are inappropriate for SMPS designs- too long recovery time even for a pig of a chip like 34063- and not even specified so the specs can be met yet the diodes can be very different.
Use a Schottky diode like the datasheet shows. An ultra fast diode such as UF4004 can also be used.
Inductor saturation is another thing to look for if that part changed.
