This connector can be found on a Kindle 3G's display (which itself is sold as Part Number ED060SC7), but I'd like to interface with it, so i need the matching socket.
Dimensions:
  • plastic body is about 8,5mm (0.335") wide (long side)
  • all contacts combined are about 7mm (0,276") wide
  • there are 34 pins (perhaps 36 if the ones at the ends count?).
  • which would give them a distance pin-to-pin of about 0,4mm (~0.016")
  • length is about 1,5mm (0.06")
  • height (above flex-board-surface) is ~1mm (~0.04")
I would like to know the name of the part and who manufactures these. Extra points if somebody knows of a breakout to something tinker-friendly!
mezzanine connector
used to connect boards together in a layered fashion
this one is Panasonic AXT434124
mates with AXT334124
https://ca.mouser.com/ProductDetail/Panasonic/AXT334124
found by searching for technical drawings of ED060SC7
here is a breakout board that you could use (you would have to solder the connector)
https://www.amazon.com/Schmartboard-SOP-0-4mm-Pitch-Version/dp/B00OGLBA6C/ref=sr_1_8?ie=UTF8&qid=1514326345&sr=8-8&keywords=SchmartBoard+0.4
|improve this answer|||||
  • \$\begingroup\$ thank you very much! More than I could have asked for :-) \$\endgroup\$ – amenthes Dec 26 '17 at 23:45
  • \$\begingroup\$ looking for technical drawings of the whole assembly didn't come to my mind! I found a PDF and it's amazingly useful :-) Thanks again! \$\endgroup\$ – amenthes Dec 26 '17 at 23:48
