Couldn't find the answer on the internet. The leads of VZ1 component are directly connected to mains.
Therefore in this context, the component which makes most sense is the varistor (often a Metal Oxide Varistor or MOV). [A normal Zener Diode, for which a designer might also use the VZ
component designator, would not be connected across the mains.]
Varistors are often used to suppress high-voltage transients and are directly connected across a device's mains supply input in that case.
\$\begingroup\$ Thank you. Do you know what R1A means? Is that some kind of resistor? Looks like pcb doesn't have R1B \$\endgroup\$– QeeetDec 28, 2017 at 0:47
1\$\begingroup\$ @Qeeet - "Do you know what R1A means? Is that some kind of resistor?" The use of letters after a component designator, is not well-standardised so I can only guess. My initial hypothesis would be that, yes, it's some kind of resistor. However it would require the rest of the (missing) input circuit to be reverse-engineered, to help explain why
R1A
would be used, with those extra components fitted. It might be that there is a capacitor (CX1
?) which, if fitted, would be discharged byR1A
, to prevent someone who unplugged the device and then touched the pins, from getting a "jolt". \$\endgroup\$– SamGibson ♦Dec 28, 2017 at 1:01 -
1\$\begingroup\$ CX1, CX2 and CY1 are probably X and Y capacitors, special capacitors designed for AC line inputs. It looks like R1A goes under CX1 probably to discharge the capacitor as you suggested. \$\endgroup\$ Dec 28, 2017 at 4:36
About the only Z type part that belongs across the power line is a bidirectional MOV. It ought to be after the fuse
VZ1
in this specific context. \$\endgroup\$
