I’ve been wanting to ask this question for a very long time.
My main thing is knowing if a low power, low current motor is possible using a BPW34 photodiode. I hope you guys can help. Thank you!
I purchased a 3 in 1 soil tester meter https://www.ebay.com/p/3-in-1-Soil-Tester-Meter-for-Garden-Lawn-Plant-Pot-Moisture-Light-Ph-Sensor-Tool/1712433238?iid=311911276636
that comes with a analog panel meter
https://www.jameco.com/z/AVM7030-Velleman-Analog-Voltage-Panel-Meter-30-Volt-DC2-8-X-2-4_316654.html
In the center it has a photodiode BPW34
https://www.digikey.com/catalog/en/partgroup/bpw34/12351
The needle of this meter turns at very low voltages and current. I measured everything and will post the exact info below.
My question is
How do engineers calculate how much voltage, current, coil resistance, and magnet strength a motor will need to be able to make a full turn?
Let’s suppose the engineer had a smaller magnet, and he wanted to make a smaller meter. How would he know how many coils turns (resistance), voltage, and current he would need to make this thing turn?
For example, in this science project
https://www.education.com/science-fair/article/no-frills-motor/
How did this person know how many turns (resistance) he needed, voltage, current, and magnet strength to make that motor turn?
In my meter, when you apply .5 mV and .5uA it will turn until stopped by a piece of metal at the bottom that holds the magnet.
The coil measures 794 ohms. The armature (coil) and needle weighs .415 grams. The photodiode causes the coil to turn to full 180 degrees when it reaches .5 volts and 500uA (micro amps). The bipolar circular magnet weighs 1.81 grams and has about 12 grams of lift force.
Images of my parts
https://www.flickr.com/photos/153503439@N02/39315572332/in/dateposted-public/ https://www.flickr.com/photos/153503439@N02/39315594942/in/dateposted-public/ https://www.flickr.com/photos/153503439@N02/39315601022/in/dateposted-public/ https://www.flickr.com/photos/153503439@N02/38637464474/in/dateposted-public/
Another question that I have is
Since the magnet will stop at 180 degrees when the poles of the coil attract the opposite poles of the magnet, is there a small ic I could use to invert the current so that it would continue to spin? Don’t worry about the stopper. Thank you!
  • \$\begingroup\$ This problem is all about friction and air resistance. Both aren't easy to calculate and any reasonable engineer would simulate, test, test, test, test, test, test, test, test, test … \$\endgroup\$
    – Janka
    Commented Dec 28, 2017 at 6:53
The DC motor torque is proportional to current which results in acceleration unless opposed by a spring whose torque increases with deflection.
The result is the calibrated deflection = a calibrated current. When added with a scaled series resistor, then it measures voltage.
The analog meter is often measured in kΩ/V. Large meters were 50kΩ/V while small meters were 1kΩ/V.
BLDC motors use a Hall magnetic field detector to sense a position used to commutate the coil current with electronic toggled power switches called a "Half & Full bridge driver". There are many different types using FETs.
The rules for ammeters are similar to motors with variables like magnetic field strength, number of turns, diameter and gap between the coil and magnet, as discussed in white paper.
http://www.ni.com/white-paper/14921/en/
As far as using solar power of tiny photo diode (PD) to drive a tiny motor, I recall a small 5mm PD response of 0.5mA per mW of optical power, thus the power in the motor cannot exceed this.
  • \$\begingroup\$ That site is above my understanding since there is a lot of trade knowledge and terminology that I am not familiar with.I have a smaller magnet that can lift 15 grams with .5 mm of spacing between magnet and metal.I'm assuming I would need 15 grams of torque to move the coil with the needle away from the pole.This is a complicated study that I guess I will just have to do trial and error since that are so many factors, like strength and thickness of the magnet, the wire gauge, the width and height of the armature.It would be a neat thing to see a tiny motor moved by a photodiode. \$\endgroup\$
    – AverageJoe
    Commented Dec 28, 2017 at 18:31
