7
I have heard that conformal coatings can put stress on SMD parts because of expansion/shrinking while curing or because of temperature differences. How much of a problem is this?
The only value relating to this which I found in the datasheet for the coating I'm looking at was "Cured film Coating: Coefficient of Expansion: 90ppm" which I guess is about expansion while curing because it has the wrong dimension for a thermal expansion coefficient. I assume this means that for a 20cm board there would be expansion of \$90\cdot10^{-6}*200mm=0.018mm\$ which should be negligible. Is this right?
  • \$\begingroup\$ How do I use inline Latex? \$\endgroup\$
    – Nobody
    Dec 30, 2017 at 20:45
    \$\begingroup\$ We don't have LaTeX on this webiste but we have something similar to it, called Mathjax. You have to use the \$ equations here \$ syntax. \$\endgroup\$
    – user103380
    Dec 30, 2017 at 20:51
    \$\begingroup\$ @KingDuken Thanks, that's what I meant. But seems it was already fixed for me. :) \$\endgroup\$
    – Nobody
    Dec 30, 2017 at 21:04
  • \$\begingroup\$ I haven't heard of many problems with conformal coating. Usually it is at least slightly flexible and fairly thin. I have heard of problems with potting. The larger and more fragile the component, the bigger the problem. Leaded electrolytic caps, and large inductors seem to be the most at risk. Epoxy is the least flexible potting material. Consider silicone or polyurethane potting if you are worried about breakage. \$\endgroup\$
    – user57037
    Dec 30, 2017 at 21:06
    \$\begingroup\$ @mkeith Quite possibly I (or the random internet person who is the source of that piece of information in my head) mixed up potting and conformal coating. In that case the silicone coating I'm considering will surely be fine. \$\endgroup\$
    – Nobody
    Dec 30, 2017 at 21:09
Generally this material is applied to protect components from environmental damage.
The ratio of change Stress [N/m²] pressure to Strain displacement is called Young's Modulus and the resulting force is expected to be much lower than the breaking point for components when there is thermal expansion.
Stress = Modulus × CTE × ∆T
