I'm studying ARM families,
Enter image description here
In the above image, it is written that the code by supported ARM7 can be migrated to ARM9 and others.
ARM7 uses the Von-Neumann architecture (single bus for data and instructions) and 3-stage pipeline (i.e., fetch, decode and execute). ARM9 and others use the Harvard architecture (separate bus for data and instructions) and 5-stage (fetch, decode, execute, memory and write (for ARM9)). Also, ARM7 doesn't support a memory management unit, but others do.
How can the code be compatible if the processors are using different architectures and pipelines? Won't there be any affect of architectures to the codes?
I'm assuming, as ARM9, ARM10, ARM11 have same architectures, code can be compatible, but ARM7 is different from other processors. Hence, one must do some changes in code before migrating because of different architectures. I'm wondering if it is correct or not.
  • 8
    \$\begingroup\$ I wish everyone would stop getting worked up about harvard vs von neumann. In the field a true Harvard is somewhat useless, it is an academic exercise. Modified Harvard which most processors are just means some control signals on the shared bus indicate this transfer is a fetch and that is data. Of course the memory/I/O bus has absolutely nothing to do with the processor core and instruction set nor does the nature of the pipeline. Look at x86 if nothing else, but mips, arm, pretty much every core that has seen more than one product. \$\endgroup\$
    – old_timer
    Dec 31, 2017 at 15:06
    \$\begingroup\$ Just look at MIPS, every other engineer around the world had to do some sort of mips simulator or verilog implementation, sometimes serial and sometimes parallel as well, all looking at a binary spec for the machine code, pipeline depth, signal names, etc are all up to the programmer/engineer. Take 100 engineers give them the armv4t instruction set and tell them to impement that you will get somewhere between 1 and 100 different solutions, all perfectly valid. one thing has nothing to do with the other. \$\endgroup\$
    – old_timer
    Dec 31, 2017 at 15:08
  • \$\begingroup\$ the armv4t instructions have been supported up through the armv8 implementations running in aarc32 (armv7 compatible mode). if/when you just read the arm docs you will see that over time new instructions are added. They discourage the use of swp in multi-core implementations when the core shares memory, but dont think they actually removed the instruction, most folks dont actually read about ldrex/strex or how to use it and misunderstand the swp thing. \$\endgroup\$
    – old_timer
    Dec 31, 2017 at 15:11
  • \$\begingroup\$ some of the bug and ip protection ("unpredictable results") in the ARM7TDMI have been fixed as you will see when you actually read the manuals over time. the arm9 might have added some new ones due to the nature of the technology at the time, but since then validation has gotten better. \$\endgroup\$
    – old_timer
    Dec 31, 2017 at 15:14
    \$\begingroup\$ @WayneConrad certainly not, they are still super popular. avrfreaks preceeded the arduino community, which really has no rival. sadly both are under microchip. ateml was very good with docs and their community and microchip has been pretty bad about that. they are complete products not some foreign processor ip that they pulled in as is and glued stuff around. Perhaps they still glued stuff on sure who knows where their ip originally came from but they are still a force in the market. \$\endgroup\$
    – old_timer
    Jan 1, 2018 at 21:57
4 Answers 4
19
A processor is said to be code-compatible with another if their instruction set is compatible. That is all there is to it.
Now, instruction sets can be made compatible whatever their pipeline architecture is. It is right that pipelining can have a consequence on the instructions if you only target execution speed and core silicon area, but there are always workarounds if you need to ensure some compatibility with some existing processor. It may complexify the core, but there is always a way. Look at how the architecture evolved from the 8086 to the newest Pentiums. Yet old code can still be executed.
Regarding the Von Neumann / Harvard differences, it can also be made to have minimal impact if the code and data busses actually end up to the same physical memory blocks with the same adresses (which is the case on all ARM implementations I have seen, except maybe for peripherals memory zones). There may be an impact on corner cases like the need to call specific instructions when the code is self-modifying, but in normal cases, you won't notice.
Regarding memory management, that is another story. This has an impact on the OS level. The MMU is like an additional peripheral, whose configuration has an impact on memory layout, but it doesn't change the instruction set. An algorithm is coded the same way whether there is an MMU or not.
  • \$\begingroup\$ That corner case you mention also happens when simply generating code at runtime, which is common when using JIT compilers, so depending on the use case it might be a very common scenario. \$\endgroup\$
    – Voo
    Dec 31, 2017 at 20:39
  • \$\begingroup\$ @voo that is right. But developing a JIT compiler isn't exactly a very common scenario. Executing something in JIT is indeed much more common, but the developer of the interpreted code doesn't have to be aware of this, only the developer of the JIT compiler. \$\endgroup\$
    – dim
    Dec 31, 2017 at 21:10
    \$\begingroup\$ @Voo: Every "Harvard" architecture processor I looked at turned out to be really could execute code in RAM but there was more ROM than RAM, so you can't do too much of it. \$\endgroup\$
    – Joshua
    Jan 1, 2018 at 3:37
  • \$\begingroup\$ @Joshua The distinction between Harvard and van Neumann architectures is largely academic and not really relevant to practical architectures these days. Real CPUs are a mixture of both. For example any CPU that has separate instruction and data L1 caches (so almost all of them) would be a Harvard architecture. This is also why you need special instructions here: invalidating instruction caches. \$\endgroup\$
    – Voo
    Jan 1, 2018 at 13:44
13
The idea that "code can be migrated" means that the instructions will produce the same end result. The architecture or number of pipeline stage do not affect that. e.g. the code for the instruction:
add r0,r1,r2
Will be the same on both machines and will produce the same result: r0 ends up to be the sum of r1 and r2. The latency may be longer. e.g. on an ARM7 it takes 3 cycles and on an ARM 9 it takes 5 cycles. But that will be the case for all instructions so the net result will be the same.
The real time depends on the clock speed. Thus the ARM9 may be faster despite taking 5 clocks because e.g. the ARM7 may be running at 100MHz and the ARM9 at 3 GHz.
The MMU on the ARM9 will be 'transparent' after a reset thus you will not notice that it is present. At least as long as you don't program it which ARM7 code will not do as there should be no code to touch the MMU.
A Harvard architecture does not mean code is executed differently. In fact you still need to decode the instruction before you know which data to fetch/write. It only allows the next instruction to arrive an be decoded at the same time as the data is read/written.
Having said all that, I remember there was an issues which branch instruction but that may have been when I transferred assembler to an A53 core.
    \$\begingroup\$ Yes, in most cases code that only targets the features of the older architecture should work fine. The exceptions would be code that makes timing assumptions (hand optimized, delay loops, etc) or things like self-modifying code which may rely on consistency broken by the addition of distinct code and data caches, such that it requires explicit cache flush instructions to work correctly. Fortunately these are not novel issues - portable code like an operating system kernels likely already has provisions for this on some architectures, and skilled programmers are familiar with them. \$\endgroup\$ Dec 31, 2017 at 18:34
  • \$\begingroup\$ re: branch prediction + speculative execution: this question came up on Stack Overflow recently: A newer ARM was speculating past a pop {r4, pc} when branch prediction was disabled, and speculatively loading from an address which hung the system, because the data following the function decoded as a load instruction. (And the MMU wasn't configured to disallow speculative loads from that address range.) \$\endgroup\$ Dec 31, 2017 at 21:29
ARM9 and other uses Harvard architecture (separate bus for data and instructions)
This is inaccurate. A Harvard architecture CPU has separate memories for code and data; this is not the case in any implementation of the ARM architecture. There are separate busses for instructions and data in some implementations, but they are always connected to the same memory.
Won't there be any affect of architectures to codes?
The pipeline is an implementation detail. It does not affect the programmer's model of the CPU -- in almost all circumstances, the same code will run the same way on both implementations. (The exceptions are all unusual, like self-modifying code.)
    \$\begingroup\$ Since there are two separate busses, it would be equally inaccurate to say they are Von Neumann, though. I believe the case where there are two busses (eventually with a separate cache for each) going to the same physical memory is called "modified Harvard". Still Harvard to me... \$\endgroup\$
    – dim
    Dec 31, 2017 at 8:27
    \$\begingroup\$ The claim that both busses are always connected to the same memory misses the key point. The only way you get a benefit from having two busses is if you are accessing different memories with them - either different caches in a large system, or flash for code and RAM for data in an MCU type one. If you need to make both types of access to the same memory, then you suffer an efficiency hit since they have to take turns. What is true is that these processors have a unified address space - you can use the same instructions to access both types of memory (and also typically I/O) \$\endgroup\$ Dec 31, 2017 at 18:24
    \$\begingroup\$ @PeterCordes Not that I'm aware of. It'd be incompatible with Thumb code -- standard practice is to store constants at the end of a function and use PC-relative memory references to load them. With separate address spaces, that wouldn't work. \$\endgroup\$
    – user39382
    Dec 31, 2017 at 22:31
    \$\begingroup\$ @PeterCordes AVR is almost a true Harvard architecture. The LPM/SPM instructions make it a (minimally) modified Harvard architecture. \$\endgroup\$
    – user39382
    Dec 31, 2017 at 22:52
    \$\begingroup\$ @PeterCordes - no. On either ARM or MIPS are any other unified address space machine, the only way you get different results for legal access to the same hardware address is due to cache inconsistency - which can be a real problem when software is not written correctly. \$\endgroup\$ Dec 31, 2017 at 22:56
All that "architecture" refers to here is how the CPU is wired to memory - most of the instructions and their encodings and the registers are the same between the two chips - the only way you might to run into trouble with the difference between a harvard and other architectures, or the number of pipe stages might be if you were writing code into memory then executing it ... you just have to be careful about invalidating caches
Some things like exceptions and the like may be different
  • \$\begingroup\$ Writing code as data and then executing it is impossible on a Harvard architecture. It's possible on a modified-Harvard (i.e. a normal CPU with split L1D / L1I caches). On ARM it takes an isync or something, because the split caches aren't coherent. (As opposed to x86, where the instruction cache is separate but unfortunately has to be coherent with data caches, costing transistors and power to snoop the icache and pipeline for store addresses to detect when to flush the pipeline.) \$\endgroup\$ Dec 31, 2017 at 21:23
