Most of you know that incorporation of negative feedback within amplifier is one of major considerations when designing a hi-fi amplifier. Till now, I have only dealt with differential transistor pair as input stage of amplifier and "eliminator" of distortions fed back from output of an amplifier. Although, I'm not quite sure if all kinds of distortions get eliminated by it (when compared to the original signal brought to the input of amplifier).
This circuit (proposed and made by user G36) has distorted signal, which is being delivered to voltage-amplification stage and after that it gets corrected to original (sine wave) signal being brought to the input of amplifier. It gets corrected by the differential transistor pair stage. (not shown here but: input of amplifier is at Q1 via capacitor and the output is taken from the collector of Q4).
Only problem here is that, when the distorted signal gets distorted enough, the output signal is being clipped. When input signal amplitude is low enough the signal at the base of Q4 is distorted (spiky signal), while the output at the collector of being corrected to sine wave (note that both channels weren't set to same voltage scale).
When the input amplitude was increased progressively, those spikes were higher and higher at the same time, but the higher they were, the negative half-waves were also progressively being clipped. I added potentiometer instead of RF2 to control the portion of NFB being fed to the base of Q2 but that didn't help either.
So that left me wondering for bit, and now it seems to me that all of that distortion cannot be eliminated (or corrected) after all.
I somehow didn't manage to design a differential transistor pair amplifier myself, but maybe with your help you can help me get closer to fully understand it and make one myself that would work like it should.
  • \$\begingroup\$ Can you include a picture of the clipped output? Can you also provide the amplitude of the signal you are testing with? Are you loading your amp, if yes how? I suspect you are expecting the output signal to go below ground, which is not possible. \$\endgroup\$ Dec 31 '17 at 13:56
  • \$\begingroup\$ @VladimirCravero 1.) I cannot because I don't have the circuit build up (I done that several days ago) 2.)I don't know that either but it was sine 1kHz and few hundred mVpp 3.)The amp was measured unloaded because when loaded extra effects are added circuit 4.) I am not suspecting anything here unless that distortion fed into VA stage would be corrected back to sine (or close to it). \$\endgroup\$
    – Keno
    Dec 31 '17 at 14:19
    \$\begingroup\$ I wonder where the signals are coming from? No input source? At which points are the signals measured? Voltages ? Currents? Without full information it is not possible to give a helping answer! \$\endgroup\$
    – LvW
    Dec 31 '17 at 15:03
    \$\begingroup\$ @LvW Obviously you haven't read the WHOLE question because everything is explained inside it. \$\endgroup\$
    – Keno
    Dec 31 '17 at 16:06
  • \$\begingroup\$ Keno - is this your preferred way for replying to someone who is willing to help you (answering your questions) ? I am a bit surprised. \$\endgroup\$
    – LvW
    Jan 2 '18 at 12:46
6
I'm decorating your schematic, a bit. I'm not entirely sure about your discussion, but it appears this schematic is a little more descriptive about what you are doing:
I added \$C_2\$ because I think you have enough sense already that you have one there when providing an input signal.
How should this have been designed to behave?
The question is important because there is an assumption that someone actually thought about the circuit when designing it and didn't just randomly stick parts together. Assuming a rational actor here, you can say a few things at the outset:
  1. The voltage across \$R_{C_1}\$ will be approximately one \$V_{BE}\$ through-out its operation. So this also means that the current through \$R_{C_1}\$ cannot vary too much. Also, we can say something about the magnitude, as being approximately \$1\:\textrm{mA}\$.
  2. Since there is an assumed \$1\:\textrm{mA}\$ in \$R_{C_1}\$, then the quiescent state of the circuit (without an input signal) should also have about \$1\:\textrm{mA}\$ in the collector of \$Q_2\$. The reason is that if the base-emitter voltages of \$Q_1\$ and \$Q_2\$ are the same (this is a "diff-amp" after all), then the collector currents should be the same. So a designer would have known this and planned for equal currents in both collectors.
  3. There is an Early Effect present in all BJT transistors, which becomes more of a problem if the \$V_{CE}\$ of one transistor is much different than the other. However, because of the arrangement here, it is clear that the collector voltage for \$Q_1\$ will always be "close" to \$19.3\:\textrm{V}\$ and the collector voltage for \$Q_2\$ will always be exactly \$20\:\textrm{V}\$. Given that they share the same emitter voltage, too, this pretty much means the Early Effect won't be much of an issue. Their \$V_{CE}\$ voltages will be appoximately the same.
  4. \$R_1\$ and \$R_2\$ are used as a simple voltage divider creating a mid-point voltage, half way between the supply voltage. Without a signal applied, the only impact on this divider voltage will be the required base current of \$Q_1\$. Since that base current will source from \$R_1\$, leaving \$R_2\$ just a little poorer for it, this means that the voltage drop across \$R_1\$ will be a little more than the voltage drop across \$R_2\$, so we will expect that the quiescent base voltage for \$Q_1\$ will be a little below the mid-point of \$10\:\textrm{V}\$.
  5. The collector voltage of \$Q_4\$ can vary over almost all the range of the supply voltage. Saturation of \$Q_4\$ (undesirable) occurs when the collector voltage is the same as the base voltage. But its base voltage (see point #3 above) will be close to \$19.3\:\textrm{V}\$. This means that the collector can range from almost "ground" to almost \$19.3\:\textrm{V}\$. And that is most of the output range available. At first blush, this at least suggests that \$V_{OUT}\$ has a relatively full range available to it and this fact also helps confirm that this may be the \$V_{OUT}\$ node, if you hadn't already figured it out before. (We'll come back to this, later.)
  6. \$Q_4\$'s collector current is highly dependent on its \$V_{BE}\$, with an exponential relationship. This means that the collector current will vary by a factor of 10X for each \$60\:\textrm{mV}\$ change of its \$V_{BE}\$.
  7. The collector current of \$Q_4\$ will mostly be due to the current in \$R_{C_2}\$ (ignoring the base current for \$Q_2\$ and through the NFB leg to ground through \$C_1\$.) Let's say the output will swing from \$5\:\textrm{V}\$ to \$15\:\textrm{V}\$ (again, we have to get back to this), then the variation in collector current will be the ratio of those two voltages, or about 3. From this, we could estimate \$V_T\cdot\operatorname{ln}\left(3\right)\approx 30\:\textrm{mV}\$ variation at the base of \$Q_4\$: or \$\pm 15\:\textrm{mV}\$.
  8. The above logic (10X collector current for \$60\:\textrm{mV}\$ change at the base) applies to \$Q_1\$, except that in the diff-pair arrangement only half the supposed base variation applies. We can work out now that a \$\pm 15\:\textrm{mV}\$ variation at the base of \$Q_4\$ implies a \$22\:\mu\textrm{A}\$ variation of collector current around the assumed \$1\:\textrm{mA}\$. By the rule, we would normally expect to see an increase/decrease of about \$570\:\mu\textrm{V}\$ to get there. But this is a diff-pair, so it requires twice that, or \$1.14\:\textrm{mV}\$ of signal peak to achieve it.
  9. However, point #8 ignores the loading of \$Q_4\$. Since the assumed center voltage at \$V_{OUT}\$ is (let's say) \$10\:\textrm{V}\$, its quiescent collector current should be about \$10\:\textrm{mA}\$. So we can compute \$r_e= \frac{V_T=26\:\textrm{mV}}{I_{C_Q}=10\:\textrm{mA}}\approx 2.6\:\Omega\$. (This will actually vary because the collector current will vary over that factor of 3.) Assuming \$\beta=150\$ for now, this suggests a loading of \$\approx 400\:\Omega\$. Put in parallel with \$R_{C_1}\$, we can very broadly say that the collector resistor is really only about half the value we expected. So this means the input signal has to be twice as much as we predicted in step #8 above. Or about \$2.3\:\textrm{mV}\$.
  10. From point #9, you can see that this circuit will turn something on the order of a \$2.3\:\textrm{mV}\$ change at the input to something like \$\pm 5\:\textrm{V}\$ at the output. (Ignoring the NFB.) That's an open loop gain of about 2100.
We now have an idea of the open loop gain, before adding in the NFB. With NFB closing the loop, we can compute the closed loop gain from \$A=\frac{A_O}{1+A_O B}\$, where \$A_O\approx 2100\$ and \$B\$ is the portion of the output signal fed back to the input as negative feedback. In this case, \$B=\frac{1\:\textrm{k}\Omega}{1\:\textrm{k}\Omega+10\:\textrm{k}\Omega}\approx 0.09\$. From this, we estimate \$A\approx 11\$.
So, if you supply a small signal at the input, we should expect to see about 11X at the output.
One point I wanted to return to here is that you can see that the actual voltages present at the two bases of \$Q_1\$ and \$Q_2\$ are not expected to vary all that much. We cannot tolerate much more than a swing at the output of perhaps \$\pm 5\:\textrm{V}\$. Much more than that and you will start to saturate \$Q_4\$. Given the closed loop gain, this means the input signal cannot be allowed to go much more than about \$\pm 500\:\textrm{mV}\$.
This means that the current in \$R_{E_1}\$ will vary by perhaps \$\frac{\pm 500\:\textrm{mV}}{4.7\:\textrm{k}\Omega}\approx 100\:\mu\textrm{A}\$. Given that the assumed current in it should be about \$2\:\textrm{mA}\$ (which is divided between the two BJTs), this seems reasonably "constant." So probably good enough and doesn't need any additional circuitry to stiffen that up more.
Also, assuming that there is about \$2\:\textrm{mA}\$ in \$R_{E_1}\$, we find that the voltage across it would be about \$9.4\:\textrm{V}\$. This again is close enough to what we'd guess, given about \$700\:\textrm{mV}\$ of \$V_{BE}\$ drop for \$Q_1\$ and \$Q_2\$, we once again have some assurances that there was an intelligent designer here.
I think that dots the final i and crosses the final t. This circuit looks designed. Nothing seems "out of whack" about it.
And now you know what to expect from it, too!
At the end of all this, we find that this is very likely the result of an intelligent designer (no pun intended.) This is generally considered to be a good thing.
So where does that leave things? Well, you cannot drive this circuit with more than \$\pm 500\:\textrm{mV}\$. (Perhaps a little more. But realistically that should be about your limit.) If you try and supply a larger signal voltage swing, then you can expect distortion at the output.
Also, the voltage at the base of \$Q_4\$, if you use a relatively smaller input signal, should "look" okay on the scope. About like a sine wave. But if instead you push this amplifier towards its maximum output swing, using anything more than (or even near to) \$\pm 500\:\textrm{mV}\$, then you should expect that the voltage signal at the base of \$Q_4\$ will start looking somewhat distorted (not exactly a sine, anymore.) This is entirely normal. Expect it. It will still look "something like" a sine. Just enough different that you can perhaps see that it looks "wrong."
If you now over-drive this circuit, you will push \$Q_4\$ into saturation -- perhaps heavy saturation. In that case, all bets are off and you will most certainly see non-sinusoidal results everywhere. But this isn't within the managed behavior of the circuit, so it is more of an intellectual curiosity (perhaps for those wanting to study the added harmonics under such conditions.) It's not worth investigating for most of us.
So just keep your input signal small, here. Within the range I've mentioned. I think you'll be fine with the results, then.
Cripes, this must mean that @G36 actually knew what he was doing in this case! Will such wonders never cease?
So here's an LTSpice simulation of the above circuit. I'm providing the AC analysis (log-log Bode plot):
I made it span quite a range of frequency (x-axis) so that you can see some more interesting variations. As you can see, it starts out having very little response at frequencies close to DC. You should expect this, because of \$C_2\$ blocking DC. In fact, I asked LTSpice to vary that input capacitor so that it was \$1\:\mu\textrm{F}\$, \$10\:\mu\textrm{F}\$, and \$100\:\mu\textrm{F}\$ just to make this illustration clearer. But in all cases, you can see that by the time the frequency reaches about \$100\:\textrm{Hz}\$ (from the DC side), that the solid lines (regardless of color) have reached a flat spot that seems near to a gain of 10, or so.
Here's a zoomed up picture:
Now, you can see that the gain reaches an actual gain of 11. Which is just as I calculated above. It's nice to see when that happens. It also looks pretty flat over the audio ranges of frequencies, too. Probably also a good thing. (It even looks as though it might be useful a bit higher, as well -- perhaps it could have other uses than just audio?)
The little "peak" out at the high frequency end is called "gain peaking" and it occurs for reasons you cannot easily see on the schematic because the parasitics aren't shown. Nor are all of the parasitics included by LTSpice automatically, either. Only a few. Wires have inductance but LTSpice ignore it, not knowing anything about how long your wires are or their shapes or how close they might be to other wires, etc. So the actual behavior of a real circuit you make will be probably a lot different near the higher frequency end. Luckily, it's not important here. Just ignore everything in the plot beyond \$1\:\textrm{MHz}\$. (Stuff starts getting enough different out there.)
To address your question about why the voltage at \$N_1\$ might appear "distorted" when the output signal at \$V_{OUT}\$ isn't distorted (or put another way, to put your mind at ease as to why that is okay), consider that there is a closed loop system using the negative feedback (NFB.) The diff-amp (long tailed pair) of \$Q_1\$ and \$Q_2\$ does "whatever is necessary" to control the base of \$Q_4\$ to control \$V_{OUT}\$ per the input signal. What exactly it does, isn't important right now. Just believe for now that something (currently mysterious) will happen so that the diff-amp pair is "satisfied." The details are interesting. But you don't need to know them to get the point.
Now, let's merely examine quantities to see why your scope might show a distorted voltage signal (with respect to a perfect sine) at the base of \$Q_4\$ while at the same time seeing a nearly perfect sine at \$V_{OUT}\$.
Assume the above analysis is correct (it is roughly so.) Then the center voltage (quiescent voltage) at \$V_{OUT}\$ will be close to (but a little less than) \$10\:\textrm{V}\$. This means that the collector current must be close to \$10\:\textrm{mA}\$. Let's assume for a moment that the saturation current parameter for \$Q_4\$ is \$I_S=20\:\textrm{fA}\$ (small signal device.)
Suppose an output signal at \$V_{OUT}\$ swings from \$5\:\textrm{V}\$ to \$15\:\textrm{V}\$, around the center of approximately \$10\:\textrm{V}\$. It does so with perfection and is nicely sinusoidal. No visible distortion, at all. This means that the collector current will be \$5\:\textrm{mA}\$ to \$15\:\textrm{mA}\$, around the center of approximately \$10\:\textrm{mA}\$. So let's look at the \$V_{BE}\$ required for that:
$$\begin{array}{r|l} I_C & \textrm{V}_\textrm{BE} \\ \hline 5\:\textrm{mA} & 682.4\:\textrm{mV} \\ 7.5\:\textrm{mA} & 692.9\:\textrm{mV} \\ 10\:\textrm{mA} & 700.4\:\textrm{mV} \\ 12.5\:\textrm{mA} & 706.2\:\textrm{mV} \\ 15\:\textrm{mA} & 710.9\:\textrm{mV} \end{array}$$
(The equation used is \$V_{BE}=V_T\cdot\operatorname{ln}\left(\frac{I}{I_S}+1\right)\$, where \$V_T=26\:\textrm{mV}\$ and \$I_S=20\:\textrm{fA}\$.)
Note that the peak differences are \$-18\:\textrm{mV}\$ and \$+10.5\:\textrm{mV}\$ around a center voltage of \$700.4\:\textrm{mV}\$ at the base. If you were to place a scope on the base, you'd see almost twice as large of a voltage swing in one direction as in the other. Clearly, in terms of voltage at the base of \$Q_4\$, the voltage does NOT look like a perfect sine!! Yet the output is just fine.
(I added a couple of intermediate values, too, so that you can do a slightly better job of hand-plotting out the curve, if you want to do so.)
The diff-amp pair doesn't care whether or not the voltage swing at the base of \$Q_4\$ is symmetrical. All it is doing is trying to make sure that \$V_{OUT}\$ follows \$V_{IN}\$ and it is willing to do what it takes to achieve that. And it requires a distorted voltage signal at the base of \$Q_4\$ to achieve an undistorted signal at \$V_{OUT}\$. It is enough to know that this is due to the relationship of base voltage to collector current in a BJT, which itself isn't a linear one.
This points up the fact that BJTs are NOT current-controlled devices, from the point of view of a physicist. They are voltage controlled current sources (VCCS) devices. From a designer point of view, sometimes it is enough to see them as current-controlled current sources (CCCS): such as when working out how much current to supply the base for an LED On/Off switch. (Who cares about the base voltage then?) But at times like this, explaining why a signal here might not look sinusoidal when another signal there does look sinusoidal, then knowing that it really is a VCCS helps at those times. It also helps in understanding a current mirror. Etc. You merely shift views where needed. You need that flexible mindset, so that if you see something unexpected you can dig into your box of tools and find an explanation.
NOTE:
Let me also refer you to point #6 that I made at the outset. There is a \$\approx 60\:\textrm{mV}\$ change of \$V_{BE}\$ for each factor of 10 change in collector current.
What is the current change going from \$10\:\textrm{mA}\$ to \$5\:\textrm{mA}\$? It's a factor of \$\frac{1}{2}\$, right? So you compute \$60\:\textrm{mV}\cdot\operatorname{log10}\left(\frac{1}{2}\right)\approx > -18\:\textrm{mV}\$. Cool!
What is the current change going from \$10\:\textrm{mA}\$ to \$15\:\textrm{mA}\$? It's a factor of \$1.5\$, right? So you compute \$60\:\textrm{mV}\cdot\operatorname{log10}\left(1.5\right)\approx > +10.5\:\textrm{mV}\$. Again, cool!
As you can see, I had already told you about the effect back when I first discussed the circuit. Had you fully apprehended point #6, you would have been able to figure all this out entirely on your own without the Shockley equation I handed to you, today.
BJT BEHAVIOR NOTE:
The following is going off-topic but is added in order to satisfy your curiosity, in comments below this answer, about signals you observe on an oscilloscope.
Here is how you might analyze a BJT's behavior (ignoring some effects and just focusing on only a gross simplification and excluding the dynamic resistance \$r_e\$ for now, as well):
$$\begin{align*} V_E&=V_B-V_{BE} &\text{where } V_{BE}&=n\cdot V_T\cdot \operatorname{ln}\left(\frac{I_C}{I_{SAT}}+1\right)\\ V_E&=V_B-n\cdot V_T\cdot \operatorname{ln}\left(\frac{I_C}{I_{SAT}}+1\right)\\ V_E&=V_B-n\cdot V_T\cdot \operatorname{ln}\left(\frac{\frac{V_E}{R_E}}{I_{SAT}}+1\right)\\ V_E&=V_B-n\cdot V_T\cdot \operatorname{ln}\left(\frac{V_E}{R_E\cdot I_{SAT}}+1\right)\\ V_E&=n\cdot V_T\cdot \operatorname{LambertW}\left(\frac{R_E\cdot I_{SAT}}{n\cdot V_T}\cdot e^{\frac{R_E\cdot I_{SAT}+V_B}{n\cdot V_T}}\right)-R_E\cdot I_{SAT} \end{align*}$$
Now, suppose you put a sinusoidal voltage at the base:
$$V_B=A\cdot\operatorname{sin}\left(\omega t\right)$$
Then you get:
$$V_E=n\cdot V_T\cdot \operatorname{LambertW}\left(\frac{R_E\cdot I_{SAT}}{n\cdot V_T}\cdot e^{\cfrac{R_E\cdot I_{SAT}+A\cdot\operatorname{sin}\left(\omega t\right)}{n\cdot V_T}}\right)-R_E\cdot I_{SAT}$$
Does that look like a sinusoidal result at the emitter of the BJT to you?? Even if you take \$V_{BE}=V_B - V_E\$, this base-emitter voltage still isn't going to be sinusoidal.
Now, the emitter voltage here will be across \$R_E\$ to generate an emitter current. Some of that current will wind up disappearing at the base, leaving a remaining collector current that causes a voltage drop across \$R_C\$.
Care to work out what the resulting signal looks like at the collector?? What is \$I_C\$? I'll leave that as an exercise!
Sure. Things "look" sinusoidal because they are, approximately. But in no way, exactly.
But now realize that if you remove \$R_E\$ entirely and make it zero, then you have a grounded emitter and you now know \$V_E=0\:\textrm{V}\$. Therefore:
$$\begin{align*} I_C&=I_{SAT}\cdot\left(e^\frac{V_B}{n\cdot V_T}-1\right)\\ I_C&=I_{SAT}\cdot\left(e^\cfrac{A\cdot\operatorname{sin}\left(\omega t\right)}{n\cdot V_T}-1\right) \end{align*}$$
You can get the collector current a little more directly now. But do you think it is sinusoidal?
You could apply a Fourier transform to the above equations and work out the frequency components, if you like. You could even add more to the circuitry to filter out the components you want to diminish. But in design, we often accept the warts.
Note that all the above analysis is what is called "open-loop." This means there is no NFB applied. The collector voltage is the complex product of a lot of stuff and there is nothing added (except perhaps the emitter degeneration resistor, which actually is "local" NFB) to cause the output to conform to the input.
The circuit under discussion has NFB! So while the base-emitter voltage of \$Q_4\$ can and will look a little distorted to the eye, at times. That's okay. Because there is NFB added here and used by the diff-pair to self-correct things. This is how NFB works to "linearize" a signal. By using NFB, we can get the output to better mimic the input than would happen if we just ran the electronic parts "open loop" where we'd be subject to all these crazy equations above.
YET ANOTHER NOTE:
To extend the discussion in comments and help here:
You have seen two cases of CE amplifiers. One with and one without an added \$R_E\$ for degeneration. All of the above should tell you something new, now. In cases where you see a CE amplifier without \$R_E\$, you must expect there to be some form of global NFB being applied. So you look for that.
If global NFB appears to be missing, then you know that the collector output will be distorted. More so for large signal swings, less so for smaller signal swings. (But a grounded emitter CE amplifier has a LOT of gain, so this almost always means there are large signal swings being requested by the designer of it.) It is almost always the case, though, that you will find the NFB to be present, because it will be very much needed.
Using an emitter resistor, \$R_E\$, provides "degeneration" which is important for a variety of reasons (temperature stability higher among them.) But it also provides local NFB to the circuit which helps to linearize the output signal. So in these cases, you may NOT find any global NFB present in the circuit, since the emitter resistor is doing some of that desired work.
Cripes. I've written a flurgen chapter of a book here. Look what you've made me do, Keno!!
Here is what LTSpice shows as the two output voltages for \$V_{OUT}\$ (blue) and for the base-emitter voltage for \$Q_4\$ (green):
In the above case, I've set things up so that \$V_{OUT}\$ is being exercised over its maximum range (arguably, anyway.) This helps to exaggerate the effects.
Note that the baseline quiescent value for the green curve is about \$715\:\textrm{mV}\$. So you can see that the peaks and valleys are not the same height here.
There is distortion. But to the untrained eye and without knowing the baseline quiescent voltage beforehand, the green curve trace may very well look kind of close to a sine.
Now, take a look at what happens when I cut the input signal in half:
In this case, the base-emitter voltage looks more "sine-like" than before. This is as it should be, and is expected. As the input signal causes the output to swing over smaller and smaller ranges, relative to its maximum, the closer the base-emitter swing will look to a sine. Even the baseline quiescent value cuts more closely to the midpoint.
Imagine how much closer it would get if the input signal were smaller still.
  • \$\begingroup\$ Wow, that is an awesome overall presentation of the circuit made by @G36! But I am mostly curious, if will the Q4 change the output (if it will get distorted somehow), if you add distortion within sine wave coming into base of Q4. That distortion would be x-th harmonic of sine wave. By adding that distortion, both of us could imagine it as distortion made by an amplifier itself (as I read, the power output stage would most usual distort amplified sine wave - in which case part of the output needs to be fed back to diff-amp to correct that undesired distortion). Do you understand what I mean? \$\endgroup\$
    – Keno
    Jan 1 '18 at 14:21
    \$\begingroup\$ @Keno I just added a LOT more to the answer. Read near the bottom. \$\endgroup\$
    – jonk
    Jan 1 '18 at 19:34
    \$\begingroup\$ @Keno The CE configuration will either have a degeneration resistor, or not. If it does have one, its very existence permits the emitter to "float" and therefore "follow" the base. If you are very, very sneaky about it, measuring carefully, you can still "see" that the signal between base and the emitter is still the logarithm of the collector current sine -- but it will be harder to see because of the huge voltage offset of the emitter resistor and perhaps also the smaller collector current swing compared to the quiescent collector current. \$\endgroup\$
    – jonk
    Jan 2 '18 at 19:05
    \$\begingroup\$ @Keno Glad to hear it. I think this stuff works its way in as you think more about the details. I've mentioned you may also need to do paper and pencil work. And I still think so. The mathematics I generated and the theoretic models provide one way of seeing that everything is not a sine, nor should it be, and why. The math points up details you often cannot easily see with a scope. But discussions do some of the work, as well. Keep plugging away, asking questions, etc. \$\endgroup\$
    – jonk
    Jan 4 '18 at 6:15
    \$\begingroup\$ @Keno It is the emission coefficient. Usually 1 for small signal bjt, never less than 1, and sometimes a little more than 1 for larger bjts. \$\endgroup\$
    – jonk
    Jan 13 '18 at 12:42
There are two questions here:
  1. Why is the signal at the base of Q4 distorted when the output is not?
distortion at base -> no distortion at collector
Consider that Q4 is a common-emitter amplifier with a high gain (no emitter degeneration) and a large output voltage swing (you haven't given it but I'm guessing at least 3 volts). Q4 must then be introducing a significant amount of distortion.
What does distortion mean here? It means when you put a perfect sine wave into the base of Q4, the signal at the collector of Q4 is not a perfect sine wave.
no distortion at base -> distortion at collector
Now, is there a signal you could put at the base which is not a perfect sine wave which when distorted by Q4 results in a perfect sine wave at the collector? There is-- it is this distorted wave you're seeing at the base of Q4.
The negative feedback effectively acts to pre-distort the input signal to cancel out the distortion which the circuit would otherwise introduce.
  1. Why does the bottom of the sine wave get clipped (and the signal at Q4's base get very 'spiky') when the output signal is large?
I can't blame you for losing perspective considering it worked so perfectly up to that point. Here's what you have:
And the clipping is simply because Q4's collector current drops to zero.
  • \$\begingroup\$ I don't know about Vp node you scoped in Spice but the blue and green trace is exactly what I got! But for Vp (node at the base of Q1); was the base overdriven and therefore I/you got clipped output signal because of that "extended spikes" at the base of Q4? \$\endgroup\$
    – Keno
    Jan 1 '18 at 22:22
  • \$\begingroup\$ @Keno The teal one Ic(Q4) is Q4's collector current. Where the output signal (green) is clipped you can see that the collector current is zero. \$\endgroup\$
    – τεκ
    Jan 1 '18 at 22:39
  • \$\begingroup\$ So the base of Q1 was overdriven? I assume that because there is square alike signal at the base of Q1. Or anything else happened that there is not a sine wave at the base of Q1? \$\endgroup\$
    – Keno
    Jan 1 '18 at 22:48
  • \$\begingroup\$ No. The input is OK, which is why there is no distortion when you reduce the gain. The clipping happens because once Q4's collector current hits zero it can't go any lower (it is in cutoff). \$\endgroup\$
    – τεκ
    Jan 1 '18 at 22:53
  • \$\begingroup\$ @Keno the red trace is Vp-Vn which is the differential input voltage. \$\endgroup\$
    – τεκ
    Jan 1 '18 at 23:01
Apparently the output is as desired, and you are wondering why a intermediate signal looks as distorted as it does.
This is because you are looking at the voltage of current signal. The real signal into Q4 is the current being drawn out its base. The voltage of that won't be all that meaningful to look at.
  • \$\begingroup\$ I somehow don't understand what you were really tried to expain here.. \$\endgroup\$
    – Keno
    Dec 31 '17 at 16:08
  • \$\begingroup\$ @Keno: You are trying to look at a current signal by plotting its voltage as a function of time. That doesn't work, at least not to see the true signal. \$\endgroup\$ Dec 31 '17 at 16:12
  • \$\begingroup\$ Then what is the solution for my example? \$\endgroup\$
    – Keno
    Dec 31 '17 at 16:18
  • \$\begingroup\$ @Keno: Solution to what problem? You haven't shown anything that is wrong. \$\endgroup\$ Dec 31 '17 at 17:49
  • \$\begingroup\$ But I described it, again: As that spiky signal fed into base of Q4 gets even more spiky, the output signal at the collector of Q4 gets its negative half wave progressively clipped. And I am wondering why doesn't diff-amp "corrects" properly so there would be whole sine at the output. That is the real problem. \$\endgroup\$
    – Keno
    Dec 31 '17 at 19:19
