I have a simple dimmer module with a busted Triac MAC97A6. I want to replace that component so that the module will work again but stores near my area don't have that specific component. One store keeper suggested I replace it with a BT169D which he had.
Will this work out? I had a quick look at the datasheet and the parameters almost match.
Thanks in advance
Update: Links to datasheets and circuit diagram of dimmer module
MAC97A6 Datasheet
BT169D Datasheet
  • \$\begingroup\$ Please link the datasheets and any datasheet or other information about the dimmer module. \$\endgroup\$ – replete Jan 1 '18 at 7:26
  • \$\begingroup\$ Updated with required info \$\endgroup\$ – Kokachi Jan 1 '18 at 8:11
The proposed replacement is 25x more sensitive with regard to trigger current in the relevant quadrants. Current rating is probably okay. Voltage rating is similar (and not very generous for 220V mains).
The big problem is that one is a triac and the other is an SCR, so no the proposed part is not a suitable replacement!
  • \$\begingroup\$ Can I use a BT136-600 \$\endgroup\$ – Kokachi Jan 2 '18 at 5:58
You should replace it by a Z0107MA, a 1A, 600V, four quadrant triac in TO-92 package. It is a standard product you can find both from ST and NXP.
