6
I have no idea what this is and found nothing on google
Royal 283 3W 0Ohm22J
    \$\begingroup\$ Looks like the datasheet is here: royalohm.com/pdf/product2017/CementAxialPRW.pdf \$\endgroup\$ Jan 2, 2018 at 19:33
  • 7
    \$\begingroup\$ I feel sorry for Q2. Poor thing's been decapitated o_O. \$\endgroup\$ Jan 2, 2018 at 19:37
    \$\begingroup\$ @TomCarpenter Maybe just punishment for it killing the resistor. \$\endgroup\$ Jan 2, 2018 at 19:40
  • 6
    \$\begingroup\$ They really crowded that resistor though. I doubt it will actually take 3W in that spot. \$\endgroup\$
    – Trevor_G
    Jan 2, 2018 at 19:56
    \$\begingroup\$ Trevor is saying that resistor is packed in so tight to the components next to it that there's not going to be much air circulation to help cool the resistor. It might not be able to dissipate 3W of heat when one side of it is basically covered up. \$\endgroup\$
    – JPhi1618
    Jan 3, 2018 at 20:48
4 Answers 4
35
It is an "axial-lead cement wirewound resistor" rated at 3W. Resistance is 0.22\$\Omega\$ +/-5%. Here is a datasheet.
I've been in their factory. ;-)
  • 9
    \$\begingroup\$ LOL OK you win ;D \$\endgroup\$
    – Trevor_G
    Jan 2, 2018 at 19:34
    \$\begingroup\$ I put the datasheet in the comments 5 seconds after you... \$\endgroup\$ Jan 2, 2018 at 19:34
    \$\begingroup\$ @davidmneedham alas you get no rep for comments ;) \$\endgroup\$ Jan 2, 2018 at 19:35
    \$\begingroup\$ Well, Spehro, watching them being made is passive. Why, I've blown up a few, and replaced others in a repair;-) \$\endgroup\$
    – glen_geek
    Jan 2, 2018 at 19:42
    \$\begingroup\$ Once in a while a question is just fun. Fun pictures, fun comments, and correct and complete answer. +1 for question and answers ! \$\endgroup\$
    – Marla
    Jan 2, 2018 at 21:13
9
It is a 0.22 Ohm power resistor 3Watts
It might be a 220 mΩ, 3 W power resistor.
No its not it's a 3W 0.22 Ohm power resistor.
  • 8
    \$\begingroup\$ What is the "No its not" referring to? Everyone seems to agree it's a 220 mOhm 3 W power resistor. \$\endgroup\$ Jan 2, 2018 at 20:41
    \$\begingroup\$ @OlinLathrop it was humor since I got in my answer 2s after you and Oldfart did I had to make mine look different ;) \$\endgroup\$
    – Trevor_G
    Jan 2, 2018 at 20:44
  • \$\begingroup\$ Oh yes it is! (in honour of pantomime season) \$\endgroup\$
    – user16324
    Jan 3, 2018 at 17:28
    \$\begingroup\$ @BrianDrummond "BEHIND YOU!!!!!!!!!" ;D \$\endgroup\$
    – Trevor_G
    Jan 3, 2018 at 17:54
