LatticeMico32 (LM32) is a royalty-free CPU that I use to study how a pipelined in-order CPU may be implemented.
One particular troublesome point I have trouble with is how the register file is implemented. On a pipelined CPU, you will normally have at least three memory accesses to the register file on a given clock cycle:
- 2 reads for both operands for the execution units.
- 1 write from writeback stage
LM32 provides three ways to implement the register file:
- Block RAM inference where reads/writes have extra logic to avoid parallel reads/writes.
- Block RAM inference with out-of-phase clocks which don't require extra logic.
- Distributed RAM inference.
In practice, even with distributed RAM inference, I have seen both Xilinx ise
and yosys
infer a block RAM with in phase read and write clocks. In addition, I've seen both synthesizers infer and at least part of the extra logic that the lm32 explicitly includes for a positive-edge Block RAM register file.
The inferred extra logic enables transparent reads. I have pasted the code here for lm32's explicit implementation, but I know from experimentation that yosys
generates effectively the same code to place the register file in block RAM on iCE40:
// Register file
`ifdef CFG_EBR_POSEDGE_REGISTER_FILE
Register File is implemented using EBRs. There can be three accesses to
the register file in each cycle: two reads and one write. On-chip block
RAM has two read/write ports. To accomodate three accesses, two on-chip
block RAMs are used (each register file "write" is made to both block
RAMs).
One limitation of the on-chip block RAMs is that one cannot perform a
read and write to same location in a cycle (if this is done, then the
data read out is indeterminate).
wire [31:0] regfile_data_0, regfile_data_1;
reg [31:0] w_result_d;
reg regfile_raw_0, regfile_raw_0_nxt;
reg regfile_raw_1, regfile_raw_1_nxt;
Check if read and write is being performed to same register in current
cycle? This is done by comparing the read and write IDXs.
always @(reg_write_enable_q_w or write_idx_w or instruction_f)
begin
if (reg_write_enable_q_w
&& (write_idx_w == instruction_f[25:21]))
regfile_raw_0_nxt = 1'b1;
else
regfile_raw_0_nxt = 1'b0;
&& (write_idx_w == instruction_f[20:16]))
regfile_raw_1_nxt = 1'b1;
else
regfile_raw_1_nxt = 1'b0;
end
Select latched (delayed) write value or data from register file. If
read in previous cycle was performed to register written to in same
cycle, then latched (delayed) write value is selected.
always @(regfile_raw_0 or w_result_d or regfile_data_0)
if (regfile_raw_0)
reg_data_live_0 = w_result_d;
else
reg_data_live_0 = regfile_data_0;
always @(regfile_raw_1 or w_result_d or regfile_data_1)
if (regfile_raw_1)
reg_data_live_1 = w_result_d;
else
reg_data_live_1 = regfile_data_1;
Latch value written to register file
always @(posedge clk_i `CFG_RESET_SENSITIVITY)
if (rst_i == `TRUE)
begin
regfile_raw_0 <= 1'b0;
regfile_raw_1 <= 1'b0;
w_result_d <= 32'b0;
end
else
begin
regfile_raw_0 <= regfile_raw_0_nxt;
regfile_raw_1 <= regfile_raw_1_nxt;
w_result_d <= w_result;
end
// Two Block RAM instantiations follow to get 2 read/1 write port.
Transparent reads ensure that writes to the same address as a read from another port appear at the read port on the same clock edge as well (assume the read and write clocks are synchronous). The lm32 pipeline relies on the read ports immediately reflecting the written-back register value.
However, there is extra glue logic for dealing with a stall of the pipeline and I'm not certain what this code accomplishes, even after studying the CPU implementation in detail. I have commented the code below for convenience:
// Buffer data read from register file, in case a stall occurs, and watch for
// any writes to the modified registers
begin
if (rst_i == `TRUE)
begin
use_buf <= `FALSE;
reg_data_buf_0 <= {`LM32_WORD_WIDTH{1'b0}};
reg_data_buf_1 <= {`LM32_WORD_WIDTH{1'b0}};
end
else
begin
if (stall_d == `FALSE)
use_buf <= `FALSE;
else if (use_buf == `FALSE)
begin
// If we stall in the decode stage, unconditionally
// buffer the register file values from the read ports.
// They will be used instead when the stall ends.
reg_data_buf_0 <= reg_data_live_0;
reg_data_buf_1 <= reg_data_live_1;
use_buf <= `TRUE;
end
if (reg_write_enable_q_w == `TRUE)
// If either register's address matches the register
// to be written back, replace the buffered read values.
begin
if (write_idx_w == read_idx_0_d)
reg_data_buf_0 <= w_result;
if (write_idx_w == read_idx_1_d)
reg_data_buf_1 <= w_result;
end
end
end
endif
Why is this logic required, and only for in phase read/write clocks at that? Is this code similar to any other common idioms for dealing with reading the correct data from block RAM as implemented on FPGAs (i.e. similar to how synthesizers will infer transparent read/write code)?
I would have figured that during a stall of the decode stage of a RISC CPU, logic that ensures transparent reads would be enough to make sure the read ports have the correct data output when the stall ends. By the time a full clock cycle has passed after a simultaneous read/write has occurred to the same address on different ports, shouldn't the read ports' data output(s) have settled to the new value, so we only need to buffer the most immediate data written to the write port?
I've synthesized this CPU many times using the distributed RAM inference alone (inferred as block RAM), so either this logic is not required, or ise
and yosys
are capable of inferring the extra glue logic required.
