-2
I have removed a section of electric underfloor heating mat and need to substitute the removed section with a resistor to bring up to the correct resistance for manufacturer specification.
I know the ohm value i need but i think something that can disipate the heat will be needed and not that familiar with resistors.
closed as unclear what you're asking by TonyM, Harry Svensson, Voltage Spike, Sparky256, Lior Bilia Jan 12 '18 at 15:26
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Use the underfloor heating mat, it is a resistor with the correct value and ability to dissipate the appropriate amount of power. \$\endgroup\$ – Colin Jan 4 '18 at 12:26
  • \$\begingroup\$ What you need is not clear to us, and repair questions are off-topic for this site. \$\endgroup\$ – Sparky256 Jan 8 '18 at 3:50
If you are so unfamiliar with electronics to not even know what a resistor does, you shouldn't be messing with house wiring.
Get a real electrician to take care of whatever it is you are trying to do. I wouldn't try to tell you how to do this even if we could decipher exactly what that was.
  • \$\begingroup\$ This is a comment rather than an answer to the technical question. Recommend you vtc question. \$\endgroup\$ – TonyM Jan 4 '18 at 12:55
    \$\begingroup\$ @Tony: Technically you are right since the OP never actually asked anything. However, this is the "answer" he needs to hear. Sometimes people ask (or imply) the wrong question. Responding with the right way to address the issue can still be useful. I understand the downvote, but I'm leaving this answer here. I suspect the whole question will be closed soon anyway. \$\endgroup\$ – Olin Lathrop Jan 4 '18 at 13:25
  • \$\begingroup\$ Sure and nothing personal :-) \$\endgroup\$ – TonyM Jan 4 '18 at 13:34
Can Electric Underfloor Heating be cut?
No. It is important that the correct size heater is installed based on the available space as the heating cable cannot be cut. A certified electrician should be consulted for advice on extending the cable
I'd just go with the answer "Don't do it". If you're not familiar with simple resistors, than do not play with mains. You might set your house alight, or electrocute someone.
    \$\begingroup\$ While this is the most sensible advice, it doesn't answer the OP's question, and is maybe better as a comment. I agree with you 100% though. \$\endgroup\$ – Colin Jan 4 '18 at 12:28
