When calculating gate resistor for a single mosfet, first I model the circuit as a series RLC circuit. Where, R
is the gate resistor to be calculated. L
is the trace inductance between the mosfet gate and the output of the mosfet driver. C
is the input capacitance seen from the mosfet gate (given as \$C_{iss}\$ in mosfet data sheet). Then I calculate the value of R
for appropriate damping ratio, rise time and overshoot.
Do these steps change when there are more than one mosfets connected in parallels. Can I simplify the circuit by not using separate gate resistor for each mosfet, or is it recommended to use separate gate resistors for every mosfet? If yes, can I take C
as the sum of gate capacitors of each mosfet?
In particular, I am aiming to drive a H-bridge made of TK39N60XS1F-ND. Each branch will have two paralleled mosfets (8 mosfets at total). The mosfet driver section will consist of two UCC21225A. The working frequency will be between 50kHz and 100kHz. The load will be primary of a transformer with an inductance of 31.83mH or more.
