I have a switching regulator that puts 100MHz noise onto the power supply that it shares with a microcontroller, and I'm trying to filter this noise to give the microcontroller a clean DC power source.
Unfortunately my 3 filtering attempts don't attenutate the noise very much:
Inductor circuit
InductorCircuit
  • Part: B82144F2332K000
  • Value: 3.3uH
  • Resonant frequency: 100MHz
  • Link: https://www.mouser.com/productdetail/871-b82144f2332k000
  • Expected NoiseOut/NoiseIn:
    (Based on datasheet, Zinductor = 2000ohms @ 100MHz)
    Rload/Zinductor == 100/2000 == 0.05
  • Measured NoiseOut/NoiseIn:
    248mV/670mV == 0.37
Feedthrough capacitor circuit
FeedthroughCapacitorCircuit
  • Part: YFF31HC2A104MT00
  • Value: 100nF
  • Resonant frequency: 105MHz
  • Link: https://www.mouser.com/productdetail/810-yff31hc2a104mthn
    (Based on datasheet, InsertionLoss @ 100MHz == -70dB)
    -70dB == 20Log10[NoiseOut/NoiseIn]
    NoiseOut/NoiseIn == 0.00032
    400mV/800mV == 0.5
Ferrite bead circuit
FerriteBeadCircuit
Here's a picture of the ferrite bead circuit and a scope shot (NoiseIn=yellow, NoiseOut=green), for example:
FerriteBeadCircuitPicture
FerriteBeadScopeshot
Why don't these circuits attentuate the noise closer to the expected amount?
Thanks!
    \$\begingroup\$ at 100 MHz, your parallel lines on your breadboard might act like nice little capacitors, coupling your noise through :) \$\endgroup\$ Commented Jan 5, 2018 at 12:09
  • \$\begingroup\$ what switching regulator works at 100MHz? are you sure it isn't your microcontroller? what is the decoupling like around the uC \$\endgroup\$
    – user16222
    Commented Jan 5, 2018 at 13:24
    \$\begingroup\$ Google "common mode choke". \$\endgroup\$
    – winny
    Commented Jan 5, 2018 at 13:57
4 Answers 4
Consider preventing noise pollution on the 12V supply in the first place.
Keep the loop area of the noise as small as possible - ensuring C1 is (a) adequate for U2's HF current demand and (b) as close as possible to its supply pins. And ensure L1 (or ferrite bead and/or feedthrough cap) provides enough impedance at 100MHz to prevent noise reaching your 12V supply.
Of course you can add further decoupling on the 12V supply - L2 and its impedance at 100MHz form a voltage divider, attenuating the noise on U2's 12V input.
Because they are not the actual circuits. After adding in some of the parasitic elements, the inductor circuit looks more like this:-
All inductors have capacitance and resistance, resistors have inductance and capacitance, capacitors have inductance and resistance. Every piece of wire is an inductor, resistor, capacitor, transformer and antenna.
  • \$\begingroup\$ I simulated his ideal circuit in LTspice and the output to input ratio was 0.047 - almost identical to the result he expected. Yet the actual result was 0.37, nearly 8 times higher. Possible explanations are: 1. Real circuits have parasitic elements which affect the results. 2. Conventional electronics theory is useless and LTspice is a fraud! \$\endgroup\$ Commented Jan 5, 2018 at 19:16
  • \$\begingroup\$ Thanks Bruce. I figure the problem is due to parasitics, but what's throwing me off is that the datasheets seem to claim behavior that I could realistically expect, rather than idealized behavior. The circuit that I built doesn't seem that far off from what I would finally implement on a manufactured PCB, yet its performance is totally different from the datasheet. \$\endgroup\$
    – Dave
    Commented Jan 6, 2018 at 9:06
It seems you tried all but the obvious, which is a inductor in series followed by a capacitor to ground. As Brian Drummond said, put that on all the power feeds, especially the one making the noise.
You may actually not need to filter the power to the microcontroller at all. The micro isn't running at 12 V, so you have a power supply between the noisy 12 V and the micro anyway. That's going to make its own noise, so even starting with a perfectly clean 12 V isn't going to get you much.
Microcontrollers are tolerant of some noise on their power. They are run from switching power supplies routinely. Any competent switcher will have less that ±50 mV noise. That shouldn't cause any problems in most cases.
You do probably want the analog section power input (assuming your micro has one) to be cleaner. I usually filter the main power thru a chip inductor followed by 10 to 20 µF to ground. Sometimes I use two of these in series. The analog power input of a micro usually draws little current, so the little voltage drop due to the DC resistance of the chip inductors is inconsequential. My jellybean chip inductor is 950 nH and 600 mΩ. Even two of those in series times 20 mA, for example, only drops 24 mV.
  • \$\begingroup\$ This does not answer the question; Why does what he is measuring not match what he is expecting? See my answer. \$\endgroup\$
    – user173292
    Commented Jan 5, 2018 at 14:17
    \$\begingroup\$ @Vin: Right. I wasn't attempting to answer that. It does, however, answer the broader question of what to actually go and do. \$\endgroup\$ Commented Jan 5, 2018 at 14:40
What is your probing technique like?
If by chance it involves a little (usually black) wire with a croc clip one one end dangling off the side of the scope probe that that is likely your problem, it adds a huge amount of inductance AND can act as an aerial.
There are many web pages discussing good probe technique.
My favourite approach to noise measurement is to stick the scope in 50Ohm AC coupled mode (Or use a DC block and feed thru terminator) and use a bit of coax soldered right across whatever point I want to measure to connect the scope, usually MUCH better then a scope probe for this sort of thing.
regards, Dan.
