Seeing a lot of mixed infomation around involving ground planes on multilayer boards. For a mixed signal mulitlayer PCB which is the preferred method? I know every board is different and it depends what your board is doing but I see alot of people with isolated ground planes yet Henry Otts advice is to do the exact opposite and partition the board in segments. Any advice or comments on this would be great!
    \$\begingroup\$ I rarely split planes (there can be occasions): electronics.stackexchange.com/questions/185306/… \$\endgroup\$ Commented Jan 5, 2018 at 13:00
    \$\begingroup\$ Possible duplicate of Analog & Power Ground Planes Doubts \$\endgroup\$
    – Trevor_G
    Commented Jan 5, 2018 at 13:12
  • \$\begingroup\$ @PeterSmith Thanks peter So if I understand correctly still use an isolation barrier but dont completely cut that segment of the board off from the rest of the board? Would I place this "gateway" under an opto-isolator for example? \$\endgroup\$ Commented Jan 5, 2018 at 13:56
  • \$\begingroup\$ It is extremely difficult to give detailed advice without seeing the proposed layout. \$\endgroup\$ Commented Jan 5, 2018 at 13:59
  • \$\begingroup\$ @PeterSmith Yes i understand completely I'm doing layout as we speak so I'll be sure to put something up when I have it. \$\endgroup\$ Commented Jan 5, 2018 at 14:02
It really depends on your design. Henry Ott says it will simplify your design in general.
Off the top of my head there are a few reasons you don't want split planes:
1) It turns your board into a dipole antenna
2) Crossing a split plane with a trace is bad because it increases inductance and complicates the paths for return currents.
There are reasons for splitting planes, in some cases it can reduce common mode noise or noise on the analog side of the ground plane. If your isolating your analog section completely (which I would not recommend, but is sometimes necessary) then you will need split planes.
  • \$\begingroup\$ Yeah I have seen this image before just gets confusing when half of the manafacturers reccomend split planes! If you have any advice on how to layout the power plane using this method it would be greatly appreciated! \$\endgroup\$ Commented Jan 9, 2018 at 14:05
  • \$\begingroup\$ Like I said in the post, it is completely design dependent \$\endgroup\$
    – Voltage Spike
    Commented Jan 9, 2018 at 16:21
I'm preparing some blog pages/content about this topic. But I'll summarize here.
If no charge moves between the analog and the digital sections, then you can pick either options.
Given mixed-signal systems tend to NEED to move digital data and control signals back and forth between the Analog and the Digital sections, there are several approaches;
1) use fiber optics to move data; I saw this used on an IR camera head inside a gymbol (track incoming missiles) with noise floor achieved of 17 nanoVolts/rtHz. There were no beathotes in the images.
2) adjust system timing
3) minimize the digital-interface charge injection; I once used +I and -I and Iref/2 (to set threshold) between FractionalN Synthesizer core-algorithm and the PLL charge pump; reference spur was shockingly low at -105dBc. The key is the balanced +I and -I, where lotta charge was moved but nearly nulled.
4) study the system ringing; understand why your silicon parts have ringing and study how to manage that ringing.
Just some thoughts.
