Preliminary: I know basic model of DC motor which depends of two electric parameters such as voltage/rpm and current/torque. There are two models electrical - resistance, back EMF, and optional inductance of coils. On mechanical side there are torque, speed and optional moment of inertia.
Question: What is the real limit for maximum voltage/frequency applied to BLDC motor if motor will be powered by high range current source ? My presumption is that motor's mechanical construction is limited mostly for currend and torque and when higher rpms are needed then should be able to increase voltage/frequency of motor.
How it is with both case permament magnet or induction asynchronous motors? Why some datasheets of similar motors have different both nominal/maximum rpm and voltage specified?
To summarize last talk thanks to Gregory Kornblum
  • Some motors have ratings 24 V and could operate for higher voltages. My assumptions:
  • Controller current source has filtered signals before output rails such that only envelope is driving motor's phases.
  • Bearings and mechanical construction of the motor is strong enough to handle high rpm.
  • There are fast mosfets to handle phases currents.
Any further explanation/ideas or confirmation to the subject?
You are correct in assuming that the basic mechanical construction of a motor limits current and torque more than it limits voltage and speed. Speed is limited by the friction losses that the bearings can withstand. The aerodynamic drag (windage) is also a factor. Another factor is balancing of the shaft and rotor to minimize vibration. At some speed, centrifugal force stress on the rotor may be a factor. Voltage is limited only by the winding insulation.
None of those factors have really "hard" limits. For most motors, those items are conservatively designed so that motors operated within the voltage and speed rating will have quite a long service life expectation. Exceeding the published ratings will reduce the expected motor life, but the ratings can often be exceeded by 50% and even 100% without very rapid failure.
Note that the aerodynamic drag can increase quite rapidly, add significantly to the torque load on the motor and increase the current. However if the current is held within the rating, tee motor will not overheat. In effect, motor's torque rating and efficiency will be reduced.
Note also that load vibration and other load forces effecting the motor bearings can also increase with increased speed. The bearings are definitely the leading candidates for the first thing to fail.
If you are designing a race car and can afford to replace the motor after every race, it makes sense to push the limits a long way. If you are designing production equipment and have to cease production of expensive products if something fails, you may not want to operate everything below the ratings.
Permanent magnets are not as robust as the copper bars embedded in the rotor of an induction motor. They are brittle and not very strong mechanically, so at high rpm they may disintegrate due to centrifugal forces.
If the magnets are glued onto the rotor then at higher temperature the glue may soften, allowing the magnets to move around or even completely detach from the rotor (not just theoretical - I have repaired several motors that this happened to). They can also be permanently demagnetized by high temperature and/or high current.
Operating the motor at higher voltage increases the potential peak current draw, and also often increases operating temperature. Magnetic losses increase at higher rpm, so even if mechanical forces don't destroy it there is a hard limit above which the motor will dissipate more power than it can handle even without a load. Most BLDC motors use Neodymium magnets which have a relatively low Curie temperature, so they are usually the first to go when the motor overheats.
Motors with 'similar' external dimensions and electrical specifications may have quite different internal construction. A motor designed for higher rpm may have its rotor wrapped in Kevlar to hold the magnets on. It may have better bearings and be finer balanced to reduce vibration. To reduce magnetic losses it might have thinner stator laminations, reduced magnet coverage, larger air gap, different number of poles and/or winding pattern, or even a totally different core (slotless, ironless).
Specifications may also vary depending on the expected application. A motor designed for continuous duty in an enclosed environment may be rated lower than a similar motor used for traction.
  • \$\begingroup\$ I hope you mean centripetal forces, nothing ever disintegrated due to the centrifugal pseudo-forces ;) \$\endgroup\$
    – user173292
    Commented Jan 7, 2018 at 0:01
    \$\begingroup\$ That's exactly what I mean. As far the magnet is concerned, it is experiencing a centrifugal force. Centrifugal force "In Newtonian mechanics, the centrifugal force is an inertial force... directed away from the axis of rotation that appears to act on all objects when viewed in a rotating frame of reference." \$\endgroup\$ Commented Jan 7, 2018 at 1:20
  • \$\begingroup\$ No the magnet does not experience a "centrifugal force" because in reality There is No such thing. Its a result of people mistakenly thinking that the force was pointed outwards. the only real physical force that exists is the centripetal force it is the force pointing in to center of rotation. \$\endgroup\$
    – user173292
    Commented Jan 7, 2018 at 1:28
  • \$\begingroup\$ A fictional force never affected anything. This is highschool physics by the Way \$\endgroup\$
    – user173292
    Commented Jan 7, 2018 at 1:30
  • \$\begingroup\$ 'Operating the motor at higher voltage increases the potential peak current draw, and also often increases operating temperature' This is not essentially true if controller has current mode output then only some potential spike could appear due to discharging capacitors then smps circuit should response by limiting current almost immediately. However from your and previous post there is conclusion of the limits caused mainly by mechanical aspects and rather not electrical at all as I see as far. \$\endgroup\$
    – busbar
    Commented Jan 7, 2018 at 7:15
Frequency of what? If you are talking about PWM, then you the only limiting factor i can think about and is related to the motor is capacitance between coils and the enclosure, so too high frequency would leak to the cage. But it's about really high frequencies, you drive will limit you much lower by switching losses, power for gate drivers, etc.
Voltage- again, normal motor can stand voltages that are orders of magnitude highet than its ratef voltage for sane operation. This is why in many applications they use a 310V drives to move small 24V motors.
Bearings will fail much earlier than with BEMF you will reach anything close to the physical voltage limit.
Bottom line is that motor is a so complex and diverse creature that to understand its limits you really need to have a good view of the system and the motor itself.
  • \$\begingroup\$ PWM is internal implementation of controller I am rather focused on envelope of the apllied signal for phases coils eg trapezoid or sinusoidal. For typical range of rpms it will be no more than let say 1 kHz. or 20k rpm. PWM signal should be filtered before output so capacitance is not a trouble in this case. \$\endgroup\$
    – busbar
    Commented Jan 6, 2018 at 8:20
  • \$\begingroup\$ Bearings also should last at least 50 k rpm. Let assume that mechanical construction is strong enough. Consider this example: miromax.lt/en/m-6/c-39/… it has only 1k rpm nominal speed. I suppose this can easly handle 5k rpm in relation to pure mechanical construction. \$\endgroup\$
    – busbar
    Commented Jan 6, 2018 at 8:38
  • \$\begingroup\$ You have to take a look at some motor. It can be rated at 4krpm @ 24V. Physical limitation on voltage can be thousands of volts, because in coil there is no adjacent wires with too different voltage, so limitation comes from wires outside the motor or anything like that, probably even the manufacturer didn't bother checking what is the limit. You say mechanically you could go to 50krpm? That's great, but think what would limit you before that. Can you switch phases for trapezoidal commutation fast enough? Maybe your encoder is not fadt enough? \$\endgroup\$
    – user76844
    Commented Jan 6, 2018 at 8:45
  • \$\begingroup\$ These are my thoughts I need to do some research before doing tests and building controller. Some mosfets are capable to switch for even MHz good design of controller is not unreal for such conditions. Thanks for your commitment and waiting for another ideas explanation. As you see it is not obvious thing. \$\endgroup\$
    – busbar
    Commented Jan 6, 2018 at 8:50
  • \$\begingroup\$ You know, there is a better way to approach this. Undestand your application, understand what you need, and then do that. You are right about that there should not be limits to voltage frequency or whatever. Design may be better or simpler. But you definitely don't need to push the limits if your application doesn't require that. The world of servo is my world, and i am telling you, it's a huge effort to push limits and do what no one does. \$\endgroup\$
    – user76844
    Commented Jan 6, 2018 at 8:52
