See also my previous question:
How should I bypass switches
Where I made a circuit directly by mains, and as proposal by very useful comments to use a separate 'control' circuit at 9 or 12V.
However, according to this video:
How to Build On-Stage Light Boxes for Your Band
the switch under the 'plateau' is directly connected to 220V.
However, in my case I want to make a very important change: I don't want to use plexi glass, but a metal grid (like this):
Grid
I assume it would not safe to make a switch directly under this iron grid that is connected to 220V? Or is it actually not really safe for the plexi glass solution as in the YouTube video neither?
(Btw, I think according to the related earlier question, I'm going for a transistor/relay/triac solution anyway).
And a side question: another band I seen, uses a foot switch instead of a switch under the grid. I'm almost sure that foot switch is connected directly to mains (meaning 220V goes through it). Now this is seen quite often with living room lamps etc... but I wonder if this is safe on a music stage (what if someone would drop beer over it, and the foot switch is not 100% 'closed' somehow) ?
  • 4
    \$\begingroup\$ You were advised to use a low voltage on the switch - why do you think people on here would change their position in regards to safety ? Just because you have found someone else’s solution... \$\endgroup\$
    – Solar Mike
    Jan 6, 2018 at 12:25
  • \$\begingroup\$ @Solar Mike ... because in my original question I used a foot switch and in the you tube video the switch is 'hidden' under the plexi glass plate. \$\endgroup\$ Jan 6, 2018 at 12:42
    \$\begingroup\$ And are you using a plexiglass plate (insulating) ? Or a metal grid (conducting)? \$\endgroup\$
    – Solar Mike
    Jan 6, 2018 at 12:44
    \$\begingroup\$ Please use an IP65 encapsulated switch as one of these ebay.de/i/332485876118?chn=ps&var=541548066447. Do the wiring inside the lamp case. The lamp should also be IP65 rated. \$\endgroup\$
    – Janka
    Jan 6, 2018 at 12:49
    \$\begingroup\$ Stage lighting technician here: If you're worried about liquid on stage, make sure all electrical components (especially connections) are elevated off the floor/bottom of the box. IP rating is good, but not having anything that can sit in a puddle is key. \$\endgroup\$
    – RedBassett
    Jan 7, 2018 at 19:37
9
There absolutely is no issue in using a correctly rated momentary switch to turn on and off a lamp directly. After all, our houses are full of wall switches, foot switches, and even not so safe kinda sloppy switches from non controlled markets.
But there's a catch: there is no issue if you can ensure that the switch will operate in a proper environment at all times. If you can understand what a proper environment is, and enforce it, then go ahead with whatever design comes to your mind.
Using a low voltage switching circuit is certainly a hassle, because you need a transformer, a PCB, whatever: it's a mess.
But consider this: you can buy an off the shelf relay, connect the mains voltage to it, put everything in sealed box like what they use to make electrical connections in gardens, and just run around your low voltage control wires.
With low voltage control you can do a number of things that are more difficult and costly to do with the mains directly: you can add crappy foot switches everywhere, and enjoy the light going on and off when your drunken guitarist drops a pint on it while smiling to that girl that was "definitely looking at him". You can add alwasy on, always off switches at no cost. You can parallel foot switches so that you can turn the lights on and off from various points in the stage. You can add a microswitch to your drummer pedal and have cool, perfectly timed, blinking lights. You can even program an arduino or whatever to produce super cool effects in the future, if you want.
Be safe on stage, if you have to ask if it is safe assume it is not safe.
  • \$\begingroup\$ Thanks for this answer ... actually, eventually when I have more time, I want to connect the light to a DMX cable (the light already supports DMX), and I am already working on a hobby project to do things with controlling all lights, including the stage box :-) \$\endgroup\$ Jan 6, 2018 at 12:45
  • \$\begingroup\$ +1 for that girl that was definitely looking at me. Er... I mean "him." :) \$\endgroup\$
    – Edward
    Jan 6, 2018 at 19:30
The light box video has design flaws but works with the weight of stepping on one side only. But at least it is rugged and insulated. The choice of the >=20A switch and it’s height are critical.
Safety of using a metal grid instead of 1/4” plexiglass depends on your common sense of insulation and keeping it dry. Grounding it may or may not be a wise idea with unknown guitarists vacuum tube amps , leather shoes and leakage hum.
( some vacuum tube guitar pre-amps may have unsafe leakage leakage current available to go thru the strings. Leather boots are known to be good for small current leakage from sweat absorption, good for anti-stat, but may induce hum if there is leakage to metal grid. Then again, if grounded , it may also increase or reduce hum. and impossible to predict if it is safe)
Enclosing a 500W Halogen heat lamp is not a great idea but for pulsed flood light, it does the job OK.. Consider cheap LED flood lights, faster response time without the tungsten PTC time constant. But I think the stomp timing effect gives it a smoother power effect with the one foot stomp control on the corner switch.
Plexiglass vs metal grid? I think you could make the metal grid work, if you guarantee the switch to be insulated under all conditions ( coat exposed contacts with silicone) and ground the grid.
  • \$\begingroup\$ I will use a 12W RGBW led par lamp (it's already in a case, not grounded, cannot change that). I think I will go for the low voltage solution (using a 12V adapter), I assume that should not cause hum problems. Also with 12V, grounding is not so important (the LED par itself will run on 220V but is isolated from the switch). \$\endgroup\$ Jan 6, 2018 at 16:00
    \$\begingroup\$ +1 for grounding the metal grid. You don't want to electrocute someone getting on or off stage. Better to trip a breaker before that would have happened. As for getting "buzzed" or killed by a live guitar amp: either fix the amp or destroy the amp. Seriously, "vintage" and "that sound" no longer matter if it's a death trap. \$\endgroup\$
    – AaronD
    Jan 6, 2018 at 23:34
  • \$\begingroup\$ If you still think that isolation could work, consider two amps that "leak" differently and are used simultaneously... \$\endgroup\$
    – AaronD
    Jan 6, 2018 at 23:35
It will be safe if the grid is grounded and of course the switches insulated and designed for this purpose (strong enough mecanicaly). Yet, it will be safer with 12V. As Vladimir Cravero said, with 12V you have more flexibility for further sophistication without worrying too much about safety.
  • \$\begingroup\$ Thanks ... I will first try without grounding (cause it might cause hum because of speakers). I'm going to use 12V anyway (or even less). \$\endgroup\$ Jan 6, 2018 at 21:33
