I have a multi-tester. And its model name is J0411A. And it looks like thisenter image description hereYou might see that this multi-tester includes a resistor tester. When I set the tester to x1 of Ohm section and connect + to - directly, I get about 2.6 Ohm. When I set the tester to x10(other things are same), it points 1.8 which it means 18 Ohm. Why two numbers are different?
Analog meters I've used had a "zero adjust" knob for setting the meter reading to zero when you short the leads. This adjustment has to be made each time you change the scale.
  • \$\begingroup\$ But this option is not in this meter. @나진열 have you found this setting on your meter? Because I can't see it in the picture. \$\endgroup\$ – Wrichik Basu Jan 7 '18 at 15:18
  • \$\begingroup\$ @WrichikBasu: The little knob immediately above the red lead is marked "0Ω", which should be a rather obvious clue! \$\endgroup\$ – Dave Tweed Jan 7 '18 at 15:36
  • \$\begingroup\$ @DaveTweed I couldn't read that. I thought that to be a fuse. Well, thanks for pointing that out. \$\endgroup\$ – Wrichik Basu Jan 7 '18 at 16:05
  • \$\begingroup\$ @jsotola the question is not posted by me, neither do I have an analog multimeter, nor do I have any experience with one. I just commented based on the picture. \$\endgroup\$ – Wrichik Basu Jan 8 '18 at 10:02
