I try to implement a VCP on a STM32F105RB with the STM32_USB-Host-Device_Lib_V2.2.0
I was able to compile the Code sucessfully.
My Hardwareconfiguration is the following:
Mini USB directly (without series resistors) to D+ and D- of the STM32. +3.3V to PA9 (for BusSensing)
After debugging start in atollic, the host detects a new device but it is not listed in the device manager.
After few seconds, i get a BusFault on the STM. The BFARVALID is set and the BFAR is 0x1FFF 7A10
This is interessting, since the Addressspace between 0x0804 0000 - 0x1FFF AFFF is reserved.
If i restart the firmware 2-3 times (NOT the debugging process, only do a soft reset not a hard reset) and click run again, then it detects the VCP correctly after some tries. It shows a not working COM9 and a working COM10 in the device manager. And it does not end up in the bus fault anymore.
Can anybody help me solve this problem?
Thanks
Attached are the Registers at BusFault and the Dissassembly.
Memory MAP
Dissasembly of the RAM Address
Dissassembly of the SP Address
CFSR Register at BusFault
MMFAR Register at BusFault
Update:
Layout: Layout of the Breakoutboard
Schematic: Schematic
Documentation: Link
For VBUS-Sensing, i have connected PA9 with +3.3V. My board is powered through USB. So as soon as i plug in the USB-Cable, the board get its power and as soon as 3.3V is up, VBUS-Sense (PA9) is also high.
  • \$\begingroup\$ Could be a problem with your PCB layout, causing glitches on the voltage lines (VCC). Schematic and layout could be helpful... \$\endgroup\$
    – Turbo J
    Jan 7, 2018 at 12:40
  • \$\begingroup\$ Thanks for your comment. Here is the docu (unfortunately in german) of the board: blselectronics.ch/wp-content/uploads/2016/05/… I added the Schematic and layout to the post \$\endgroup\$
    – C. Hediger
    Jan 7, 2018 at 12:54
I found the problem.
It was in the file: usbd_desc.h
i missed to define the correct board. So it tried to get the Device ID from a wrong address. -> BUS FAULT
How did i found the problem?
I looked at the stackpointer at 0x2000fedc and saw the address 0x8004196 this was the following c-code section:
static void Get_SerialNum(void)
  uint32_t deviceserial0, deviceserial1, deviceserial2;
  deviceserial0 = *(uint32_t*)DEVICE_ID1;
  deviceserial1 = *(uint32_t*)DEVICE_ID2;
  deviceserial2 = *(uint32_t*)DEVICE_ID3;
Now i dived deeper and saw that DEVICE_ID1,2,3 pointed to a wrong address. I fixed it and now it works!
