I am looking to make something that takes a pulse of floating voltage (say from a feedback coil of on a transformer), and maintain a differential output voltage depending on the sign of the amplitude of the pulse. Then when another pulse comes along with a different sign, the output would change signs as well. I naturally looked into flip flops/latches, but after some experimentation and closer reading, I realized they do not really provide a differential output, and they do not seem to work with floating inputs. They seem to work instead with pulses of non-floating voltages and send a high to one of two nand/nor gates.
In summery: My problem is I am given an isolated voltage in the form of a pulse. I want something that will "remember" the sign of that pulse in the form of a voltage difference between two output leads.
The reason I emphasize the "differential" part is that the two output leads of a flip flop/latch will not form a complete circuit when connected through a load or something that senses voltage differences. It is just an open switch and a closed switch.
I may just be doing this wrong, or misunderstanding, but based on what I have tried, this seems to be nontrivial.
