Let's assume I have two 15V DC power supplies. These power supplies are allowed to be connected in series (per the user's manual).
I have a device that requires a signal from +15V to -15V (motor driver circuit).
Typically, I would put both my power supplies in series, I would then provide 15V (relative to ground) to the motor driver circuit to use as ground. So from potential earth perspective, the motor driver circuit has 0V as its -15V, 15V as its ground, and 30V as its 15V.
However, what would happen if I were to put both of my power supplies in series and then ground (potential earth) the middle leg from image below (i.e. ground negative terminal on power supply 1/positive terminal on power supply 2). Would I need to worry about power supply 2 shorting to potential earth?
I would guess that since each power supply can be used in series, that means the + and - terminals are isolated from ground. Thus, it would be possible to connect the middle leg to ground. This would require that power supply 2 be able to maintain a truly negative voltage relative to potential earth.
Am I correct in this assumption?
