I'm currently using SIM868 to make a GPS tracker, I wanted to know how to test tcp/ip protocol with a server. I do not have a server but got a website and a wifi connection(DIR-600M Router) , Is there any way I can use a virtual port listener or something to test the communication?
  • \$\begingroup\$ In principle yes, but only in one direction. You'll have to get the SIM868 to make a connection to your web site on port 80 and send it a GET request, and get your web site to respond with a simple page. \$\endgroup\$ – Finbarr Jan 9 '18 at 10:00
  • \$\begingroup\$ can i use port forwarding in my router to do it? \$\endgroup\$ – Arun Joe Cheriyan Jan 9 '18 at 10:24
  • \$\begingroup\$ A web site's job is to service HTTP requests from clients, which is surely how you want your tracker to work anyway. Making it do the opposite is a massive amount of work and way off-topic for this site. \$\endgroup\$ – Finbarr Jan 9 '18 at 10:33
    \$\begingroup\$ Unfortunately the question is unclear IMHO (perhaps translation / terminology issues?) e.g. you say that you don't have a server, but you do have a website. When a computer is servicing incoming HTTP requests (i.e. a website) that computer is a server (even if it is a tiny RPi etc.) as the incoming requests coming from HTTP clients like the SIM868 (client/server model). So your statements seem to contradict each other, making it unclear :-( Since this seems to be a networking question (the SIM868 is just a TCP/IP client) perhaps this should be migrated to Network Engineering stack? \$\endgroup\$ – SamGibson Jan 9 '18 at 14:39
Well, I think your best bet would be to get a virtual private server somewhere. But in the interim, you can probably test it by attempting an HTTP request on some other publicly accessible website.
  • \$\begingroup\$ Can you give me an example for 'publicly available website.'? and I'm using TCP from the GSM module. \$\endgroup\$ – Arun Joe Cheriyan Jan 10 '18 at 18:33
  • \$\begingroup\$ Google? Really, any website that you can load up in your browser should work. \$\endgroup\$ – alex.forencich Jan 10 '18 at 18:53
  • \$\begingroup\$ Maybe 'accessible' would be a better word \$\endgroup\$ – alex.forencich Jan 10 '18 at 18:53
  • \$\begingroup\$ then it should work with the website that I owns know? and what is the port number I should be using? \$\endgroup\$ – Arun Joe Cheriyan Jan 11 '18 at 6:17
  • \$\begingroup\$ Sure, if you have a publicly accessible website, then it should work. HTTP uses port 80. \$\endgroup\$ – alex.forencich Jan 11 '18 at 6:48
