It's a fairly common sort of connector, I think it's the same one that's used for GoPro batteries and a lot of cameras too, but I can't find out the name of it or where to buy just the connector.
The male part of it is 3 blade prongs.male version
female version
I want to build a couple of spare batteries to replace this one rather than pay a rather extortionate OEM rate, but I don't want to cut into the device so I'd like the connector to match.
Thanks in advance!
  • \$\begingroup\$ I should probably also add - this is a drone rather than a camera! \$\endgroup\$
    – T Kilney
    Jan 9, 2018 at 22:18
I'm not sure if this really counts as answer, but I found what I wanted via the revelation that laptop batteries have a similar connector. Ideally I only wanted the female part but at $0.31 a set I can deal with it. https://www.aliexpress.com/w/wholesale-laptop-battery-connector.html
  • \$\begingroup\$ Perfectly good answer, obviously you should measure the pin sizes and spacing to make sure they match up. \$\endgroup\$
    – Finbarr
    Jan 10, 2018 at 10:37
    \$\begingroup\$ "Sorry, your search ' laptop-battery-connector ' did not match any products. Please try again." \$\endgroup\$ Jan 10, 2018 at 17:17
