I am reading the Electrical characteristics of PIC24FJ1024GB610 from it's Datasheet http://ww1.microchip.com/downloads/en/DeviceDoc/30010074e.pdf (Page 419/468).
it mentions:
Maximum output current sunk by any I/O pin 25 mA
Maximum output current sourced by any I/O pin 25 mA
Maximum current sunk by all ports 200 mA
Maximum current sourced by all ports 200 mA
Does it mean that the maximum operational current sourced/sunk to/by the PIC24 is 25 mA, and the max current allowed to/from the I/O pins is 200mA
Thank you in advance
It means that the maximum that can be sunk / sourced by any one pin is 25mA and that the maximum that the chip can sink / source simultaneously across all pins is 200mA.
| improve this answer | |
  • \$\begingroup\$ So if we are using 100 pins or 10 pins, the max our chip can source / sink simultaneously is 200 mA , did I get that right? \$\endgroup\$ – Forat Jan 11 '18 at 9:34
  • \$\begingroup\$ Yes - for example you can have up to 8 pins simultaneously sinking the max 25mA each, or 16 pins sinking 12.5mA each \$\endgroup\$ – BenAdamson Jan 11 '18 at 19:30
