I would like to achieve 6 amps with those, is it possible?
Connectors LED Power S-38-12
    \$\begingroup\$ Short answer: No, long answer: NooOooOo. \$\endgroup\$ – Harry Svensson Jan 11 '18 at 16:29
  • \$\begingroup\$ or Maybe if each supply must be matched voltage < 0.1V and have added series R of at least 0.2V @2A (0.1ohm) with a minimum load of 10% or 0.2A each to reduce risk of oscillation. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jan 11 '18 at 17:21
  • \$\begingroup\$ @HarrySvensson Thanks! I will have two to play with then :P \$\endgroup\$ – Mike Gleason jr Couturier Jan 11 '18 at 18:36
    \$\begingroup\$ @MikeGleasonjrCouturier YeeEEaaAHhh! Timmy! \$\endgroup\$ – Harry Svensson Jan 11 '18 at 19:13
