For a while, I've been working with Arduino, but about a month ago, I switched over to using solely the ATmega328-PU microcontroller. I use the Atmel Studio IDE. So far, I have successfully blinked an LED, used programs involving buttons/switches, and used the Fast PWM function to dim an LED. Currently, I am attempting to drive a servo motor using Fast PWM, but have had little success. I have not found any source codes that work for the specific needs of my microcontroller, and I don't really have the ability to change around all the parameters, as I am still learning.
The below is the code which I have developed. It does not work, but I was hoping that someone may be able to fix it up. The servo moves in one direction, but does not stop, and just ends up grinding the motor shaft gear, indicating this could be an issue with the wave length. An additional question: is there an equation to convert degree to PWM wavelength? Thanks!
Microcontroller specifics:
- Model - ATmega328-PU
- 16,000,000 hz crystal
- 28 pins
- Using 8 bit timer
Servo:
- Servo model: Tower Pro SG90
- Servo Frequency 50 hz (is this standard?)
Code:
#define F_CPU 16000000UL
#include <avr/io.h>
#include <util/delay.h>
int main(void)
DDRD |= (1 << DDD6);
// PD6 is now an output - corresponds to OCR0A
TCCR0A |= (1 << COM0A1);
// set non-inverting mode
TCCR0A |= (1 << WGM01) | (1 << WGM00);
// set fast PWM Mode
ICR1 = 39999;
OCR0A = ICR1 - 2000;
// gives servo motor position
TCCR0B |= (1 << CS01);
// set prescaler to 8 and starts PWM
while(1)
