50
I see people suggesting specialized tools, or trying it manually with sharp knife or scalpel, why not just burning the rubber for a second or two with a lighter and just pulling it out a more suggested option?
Is there any con to this approach that I am not aware of?
  • 46
    \$\begingroup\$ google teflon flu \$\endgroup\$
    – user16222
    Commented Jan 13, 2018 at 9:14
  • 24
    \$\begingroup\$ Burning insulation off is one of those things you do in an emergency, and there are no better alternatives available. Like, an important wire on your land rover breaks leaving you stranded a hundred miles from no damned where and you've lost your knife. Burn the insulation, fix that puppy, and get some place you can fix it right. At home, use a proper tool or knife. \$\endgroup\$
    – JRE
    Commented Jan 13, 2018 at 15:45
  • 39
    \$\begingroup\$ When I was a kid, I once took a lighter flame to some dental floss. It caught fire, satisfyingly, and promptly dripped molten and burning plastic onto the fold of my fingernail. I don't know how to describe the pain, but compared to it, having my wisdom teeth pulled out was a walk in the park. So my personal thought about this is: Why in the [expletive] would anyone want to burn insulation if any other options exist? \$\endgroup\$
    – Dampmaskin
    Commented Jan 13, 2018 at 16:14
  • 49
    \$\begingroup\$ What a stupid question? Why using a lighter, when you have your teeth? \$\endgroup\$
    – user76844
    Commented Jan 13, 2018 at 22:31
  • 45
    \$\begingroup\$ I keep a cage full of gerbils and just poke the wires in to get the insulation chewed off. And the gerbils love it, so it's a win-win! \$\endgroup\$
    – Ian Bland
    Commented Jan 14, 2018 at 1:31
11 Answers 11
124
  1. It stinks
  2. It leaves soot and partially burned plastic on the wire and between the strands - those makes solder joints more difficult to make and less reliable.
  3. It is difficult to control how far back the insulation melts.
  4. Some insulation materials will soften and sag further back from the burned place, compromising the insulation.
  5. Lighters are hard on your fingertips if you use them a lot.
  6. Some wires have flame retarding chemicals in their insulation. That doesn't just stink, it can be poisonous.
  7. Teflon flu caused by breathing the fumes from overheated teflon. (Thanks to @JonRB - I had never heard of that before.)
Insulation is rarely made of rubber. It is usually some kind of plastic. There's also teflon insulated wire, which doesn't burn well but melts. Then there's what's called silicone insulated wire, which is especially heat resistant.
There's also varnish insulated wire meant for winding coils. Of all the wire types, you will most often see recommendations to burn the insulation off of varnish insulated wire. Don't.
For normal insulation, use a good tool.
For varnished wire, use (very) fine sand paper on the thicker wires. For the finer stuff, get a blob of hot, melted solder on the tip of your soldering iron and run the tip of the wire through the blob to melt the varnish off.
A good tool is expensive. I've never found one that I liked, that worked well, and that I could afford.
All the cheaper tools end up cutting into the wire. I've given up on ever finding a good, affordable tool.
I learned long ago to use side cutters to strip wire. I can do it without cutting or nicking the wire inside.
I also quite often use the smaller blade of my pocket knife. I keep it just barely sharper than dull. It can score the insulation, but not cut it well. Wire between thumb and knife blade, a half turn to score the insulation, then pull. Works like a charm, and doesn't cut or nick the wire.
I've already described magnet wire.
That leaves teflon insulated wire wrapping wire.
The wire inside is very thin, and any nick will make it break. Can't use any bladed tool on it because they will all nick the wire.
Just push the tip of the wire into contact with a hot soldering iron. I do mean just the tip - the wire almost always protrudes a tiny bit out of the insulation. Heat that tiny wire protrusion. It will get hot and the insulation will melt back maybe a millimeter or two. That's enough to solder with. Looks ugly, but it won't break off like it would if you used a bladed tool on it.
You don't want to use a sharp knife or a scalpel. You will be guaranteed to cut into the wire. (Or as RoyC mentions, your finger.)
Try it as I described. It works, though it takes some practice.
    \$\begingroup\$ You don't like the heated cutters for teflon? \$\endgroup\$
    – detly
    Commented Jan 13, 2018 at 10:29
  • 7
    \$\begingroup\$ "You don't want to use a sharp knife or a scalpel. You will be guaranteed to cut into the wire." Or finger! \$\endgroup\$
    – RoyC
    Commented Jan 13, 2018 at 10:35
    \$\begingroup\$ These are what I mean: eraser.com/products/wire-cable-strippers/thermal-wire-strippers \$\endgroup\$
    – detly
    Commented Jan 13, 2018 at 12:21
    \$\begingroup\$ Yes, this is a good answer. The only thing I would add is that it would take longer to heat the wire to strip it. I personally use diagonal cutters on the majority of wires, and only use a bladed tool for wires with very thick and/or hard insulation. But most wires have soft and thin insulation such that you don't even need to cut the insulation. Just lightly clamp with the diagonal cutters and pull quick and it will pull right off and not pull out strands. \$\endgroup\$ Commented Jan 13, 2018 at 13:47
    \$\begingroup\$ Oh, actually you can reasonably do it with a very sharp knife. The problem is, a knife of that sharpness is easily damaged by using it to cut on metal. \$\endgroup\$ Commented Jan 13, 2018 at 21:34
75
We old farts mainly do it to show off our skills to young whipsnappers. Few things are as satisfactory to see a student or new employee ogle at how, with just some side cutters, you quickly remove the insulation from a dozen wires.
Also you don't want to breathe toxic fumes or have burn residue on your wires.
  • 33
    \$\begingroup\$ Thee is a story with this: we had a student in the lab who was seeing a lab engineer doing thus that: stripping wires with a side cutter very quickly. She tried it several time and the wire got cut or the plastic would not come off. So asked him how he did it. He showed her, but in a moment of inspiration said: "any engineer can do it". He called me over, knowing I was one of the people in the company who had the same skill. We had a good laugh afterwards. \$\endgroup\$
    – Oldfart
    Commented Jan 13, 2018 at 9:21
    \$\begingroup\$ +1 for the we old farts (yeah, I also use side cutters most of the time FWIW...) \$\endgroup\$
    – user20088
    Commented Jan 16, 2018 at 5:26
  • \$\begingroup\$ @vaxquis: more like +1 for the username... \$\endgroup\$
    – user541686
    Commented Jan 18, 2018 at 5:33
30
Because using the correct tool gives you a better result with precise strip lengths without the risk of leaving combustion products all over the wire which will adversely effect solder-ability or conductivity.
  • 10
    \$\begingroup\$ The first principle of all craftsmanship: "The correct tool gives you a better result." :-) \$\endgroup\$ Commented Jan 14, 2018 at 10:35
  • \$\begingroup\$ Quite correct, in my opinion the real heroes are the electricians who wire connection after connection. It is essential that the wire is not nicked and essential that the strip is the correct length to do that you need the right tool. Those trying to do this with a pair of side cutters need not apply. \$\endgroup\$
    – RoyC
    Commented Jan 17, 2018 at 16:30
22
Whether it produces good results or not, wire insulation is one of the worse things to set on fire because "modern electric wires commonly use PVC plasticized with linear Phthalates" as insulation1. The National Center for Biotechnology Information states:
With its high content of chlorine, PVC is frequently branded as a major chlorine donor and spitefully leads to substantial formation of dioxins during poorly controlled or uncontrolled combustion and open fires.
Using your lighter certainly qualifies as "uncontrolled", and while the absolute quantities are small they are produced directly under your nose, often in a closed room. In addition to HCl and dioxin due to the relatively high Chlorine content in PVC, uncontrolled combustion produces the usual array of harmful substances like aromatic hydrocarbons and the simple, good ol' CO.
Don't do that.
1 In recent years there are efforts to phase out PVC as electrical insulation and replace it with polymers which do not contain Chlorine. Those burn cleaner, but it may still not be advisable to light them in a closed room.
  • \$\begingroup\$ At some places, PVC wiring is outlawed due to the smoke it produces when catching fire. Low smoke zero halogen (halogen-free material, LSZH) is usually used in those situations (think car-tunnels). Video's of cable flammability tests. \$\endgroup\$
    – Mast
    Commented Jan 17, 2018 at 10:08
  • \$\begingroup\$ Some more concrete experiments with actual wire have shown that in the presence copper wire, burning PVC produces less HCl because of the formation of copper chloride, but that's also fairly toxic when inhaled; NIOSH puts the permissible limit at 1mg/m3. safetydatasheets.pfizer.com/DirectDocumentDownloader/… \$\endgroup\$ Commented Nov 7, 2021 at 17:17
9
Well, it can leave burnt debris when you need to solder it afterwards and, even if it does not leave burnt plastic, it can coat the wire(s) with soot from the flame.
It can be an easy solution when dealing with very thin wires that have a varnish type coating though.
As you have seen most people use some type of tool, there are several tools that can be used - a self-stripping "plier" type, cutters with "holes" in the cutting edge to miss the wire but cut the plastic etc.
Addendum, since two more traps have not been mentioned yet:
Soot can be conductive.
Some PU insulation (common solder-through insulation on magnet wire) actually does have warnings in the datasheets encouraging you to work in a well ventilated place, because some of the pyrolysis products are seriously toxic. An open flame is not unlikely to release even more of these.
ADD: HCl when burning PVC was mentioned in another post. HCl is really bad for metallic components around. In structure fires where significant amounts of PVC insulation burned, the metal damage from corrosion by HCL can be quite significant. You probably don't want these fumes near electronics.
In addition to the other problems mentioned, when burning the insulation off, you can also heat the wire and make it brittle. This increases the possibility of failure later. For smaller wire, I like Paladin, such as the Grip P10. If you're stripping a lot of very small and/or delicate wire, you probably want a thermal wire stripper. There are countless wrong ways to do things. What you do depends on your goals, how much the project matters to you and others, budget, etc.
  • \$\begingroup\$ Heating the wire will anneal it and and make it softer, not more brittle. \$\endgroup\$
    – Navin
    Commented Jun 14, 2019 at 12:21
    \$\begingroup\$ Only under carefully controlled conditions (i.e. not using a lighter). Heating above the annealing temperature can lead to hydrogen embrittlement and other effects. Ref, Ref, Ref, Ref \$\endgroup\$ Commented Jun 15, 2019 at 16:43
In the case of magnet wire some are designed for thermal stripping by placing the ends into a pot of solder. Enamelled wire not so. All others require mechanical means. Flame stripping i will admit to having used but depending on the insulation used can be a very bad idea especially for stranded wire where they have to be soldered after, emergency measure only. Mechanical stripping is best but really needs tools designed for the diameter of wire in use , this an get expensive for different sizes and types of wire although adjustable strippers are available.
  • \$\begingroup\$ This can be tricky when you're dealing with mystery magnet wire, like a repair job, especially the very thin stuff where the normal toolbox strippers would just cut through it \$\endgroup\$
    – Chris H
    Commented Jan 15, 2018 at 9:51
  • \$\begingroup\$ True , i use a dremel and abrasive drum for the thin stuff.You can do it by hand but takes ages. \$\endgroup\$
    – beerbug
    Commented Jan 15, 2018 at 17:29
  • \$\begingroup\$ Can someone please link me to magnet wire that’s designed to be stripped by the heat of a soldering iron? Very interested for hobby projects \$\endgroup\$
    – joshfindit
    Commented Jul 20, 2019 at 23:18
It's not recommended to have flames in any environment; you could ignite something in the air or on the table. And if you use a cheap wire strip tool, you can strip a lot more cables in the same time.
Not burning it but heating it with an iron on the copper, not on the insulation. The insulation soften and can be pulled back like shirt sleeves. Use only on thin wires (for electronics).
For normal wires use this: https://cdn.manomano.fr/pince-a-denuder-automatique-P-140971-298992_1.jpg
It all depends on your project. If you are in your garage working on a small project I don't think it is a big deal. We have worked on some pretty large projects in the past and hire out to have wire pre-cut and stripped for us. We tried a lot of techniques when we first started.. tools, cutting, burning, etc... and it was just too time consuming. When we used several tools the wire would always get nicks in it and we needed something cleaner.
