So, I assembled a soldering iron kit and put the control unit in an aluminum enclosure and intend to use a Mean Well SP-240 24V power supply with it. I just wanted to verify a couple of things. The tip should be connected to chassis ground via a 1MΩ resistor and chassis ground should be connected to the Mean Well's FG (mains earth), right? To be clear, power/signal ground are seperate from chassis ground in this system and it's only the latter I'm referring to.
[not sure if it matters but this is Sweden, mains 230V/50Hz, PSU is 24V 240W (~10A), soldering iron is 24V 70W (~3A)]
