I'm looking for a device that can control an analog signal without interference. I need it to be controlled by a digital control line (0v - 5v). The input voltage (0v - 5v) should equal the output voltage (0v - 5v). It doesn't matter if the control line is active high or active low. If the control line is active then the output should equal 0v.
An example application might be as shown below. You have a blinking LED but you also want to control the brightness of the LED using a pot.
