I'm working on a circuit to turn on and off a set of lights on a vehicle.
I have to do the switching on the high side of the lights and need to use a positive voltage to trigger them on. So, I've got a little NPN transistor that grounds the gate of my P-Channel FET when it gets voltage and sends current from the battery to the light.
It works great breadboarded out but I am concerned about protecting the MOSFET and (maybe the BJT) when it's on a vehicle. Do I need a Zener or TVS diode somewhere? Where should it go? What does it need to do? What values do I need to look for when sourcing it? I am more than happy with overkill.
This is the FET I was planning on using: SQJ459EP. It has a diode built in between the drain and the source but it might need something to protect the gate?
Thank you guys for any help you can give me!
Edit: Fixed Schematic
  • \$\begingroup\$ That circuit won't turn off a load because of the MOSFETs body diode conducting. \$\endgroup\$
    Jan 15, 2018 at 20:09
  • \$\begingroup\$ WOW my brain is having a seizure trying to understand if that works drawn that way up... \$\endgroup\$
    – Trevor_G
    Jan 15, 2018 at 20:10
  • \$\begingroup\$ Where does INPUT come from? \$\endgroup\$
    – Trevor_G
    Jan 15, 2018 at 20:11
    \$\begingroup\$ I drew it up a little quick and I guess I flipped the Source and the Drain. For the input, it will probably be tapped into the low beam or an aux circuit that comes on with the key. \$\endgroup\$
    – AndyC
    Jan 15, 2018 at 20:17
  • \$\begingroup\$ I would use something in a DPAK or D2PAK. I don't like those fet's due to the small clearance between drain and source, hidden under the package. \$\endgroup\$
    – user57037
    Jan 16, 2018 at 0:58
For auto stuff you need TVS diodes pretty much on every input and output.
I'd also add D1 to protect you from kickback in the lines to the lamps.
  • \$\begingroup\$ Might as well put a Zener across Vgs of M1 as well, no? Unless the part has protection built in. \$\endgroup\$
    – user57037
    Jan 15, 2018 at 22:48
  • \$\begingroup\$ @mkeith yes why not... \$\endgroup\$
    – Trevor_G
    Jan 16, 2018 at 0:08
If you consider the precautions and tests required by Automotive designers, there are many smart switches to choose from.
e.g.Infineon BTS50060 $2.50 (1pc)
- 6mΩ with 60A (min.) inrush current
- optimized edge shaping during switching
- 3.3V and 5V compatible logic inputs
- Advanced analog load current sense signal
- intelligent Latch
- overload and over temperature protection with defined diagnostic signal
Key Benefits - Low switching losses
- EMC optimized performance
- direct connection to the uC
- Easy current sense calibration
- Latched switch-off and reporting in case of fault condition
- protection from ESD, loss of ground, loss of V+, overvoltage
