I'm trying to wire up a Schurter CPS16 capacitive, multicolour (RGB), anti-vandal switch to my PC for use as a power button.
The switch function is momentary and normally-open.
Schurter CPS16 Capactive Switch
Tech Sheet
I'm just not sure what needs wiring up, and to where:
  • I can get 5v or 12v (and Ground too, I suppose) from a Sata Power connector
  • Obviously I need to connect the motherboard power button pins
  • I have a free RGB header (and an RGBW currently in use)
I'm keen to learn what's involved! Any assistance is appreciated :)
  • \$\begingroup\$ do you have another link to the data sheet? my web browser is flagging the link you posted as being unsafe. \$\endgroup\$
    – jsotola
    Jan 16 '18 at 2:39
  • \$\begingroup\$ Welcome to EE.SE. Books and on-line documents are for teaching the basic and even advanced issues of electronics. We are not a design service or mentors per se. Learn enough to come up with your own design, then we can help you. \$\endgroup\$
    – user105652
    Jan 16 '18 at 2:39
  • \$\begingroup\$ @jsotola. My chrome browser opened the pdf with no issues. It is a secure link. \$\endgroup\$
    – user105652
    Jan 16 '18 at 2:42
  • \$\begingroup\$ @jsotola I don't have another think, but its direct from a reputable manufacturer's site? \$\endgroup\$
    – Paul Shaw
    Jan 16 '18 at 2:44
  • \$\begingroup\$ i am using chrome. it flagged the site as using an invalid certificate authority. NET::ERR_CERT_AUTHORITY_INVALID \$\endgroup\$
    – jsotola
    Jan 16 '18 at 2:47
Some reading of downloaded materials is necessary as well as awareness of the PC PWR_enable Low from normally open momentary switch contact points between input and gnd.
https://ch.schurter.com/en/datasheet/CPS
Pins 2,4,8 will be all gnd on a PC since they use "active low" enable toggle ON OFF. Normally activated on release of the switch.
