I need to model a boost circuit with the following topology:
I am interested in the resistor voltage, so I found the differential equation of each state and solved them by Euler's implicit method, alternating the equation to be solved as the state was changed.
I compared the results with a circuit simulator. Each differential equation is right alone, but when I put them together, one after the other, forming the boost switched dynamic, the result is wrong.
These are my steps:
'ON state' differential equation (just the capacitor discharge)
$$\frac{dV_{out}}{dt} = -\frac{V_{out}}{RC}$$
'OFF state' differential equation
$$\frac{d^2V_{out}}{dt^2} + \frac{1}{RC}\frac{dV_{out}}{dt} + \frac{1}{LC}V_{out} = \frac{V_{in}}{LC}$$
This is my (MATLAB) code:
R = 10;
L = 1e-5;
C = 1e-4;
Vin = 10;
h = 1e-6; % time step
sizeVector = 10000; % number of steps
t = 0:h:sizeVector*h-h; % time vector
Vout = zeros(1,sizeVector); % output voltage vector
dVout = zeros(1,sizeVector); % first derivative vector
freqSw = 5e3; % switching frequency
D = zeros(1,sizeVector); % State of switch for each simulation step (duty cycle = 0.5)
D = sign(cos(2*pi*freqSw.*t + pi/2 + 0.001));
D(D<0) = 0;
for k=2:sizeVector
if D(k) == 0
% Off state
Vout(k) = (Vout(k-1) + h*((dVout(k-1) + (h/(L*C))*Vin)/(1 + h/(R*C))))/(1 + (h^2/(L*C))/(1 + h/(R*C)));
dVout(k) = (dVout(k-1) + h*(Vin/(L*C) - Vout(k)/(L*C)))/(1 + h/(R*C));
end
if D(k) == 1
% On state
Vout(k) = Vout(k-1)/(1+h/(R*C));
dVout(k) = (Vout(k)-Vout(k-1))/h; % just for convenience
end
end
figure(1)
plot(t,Vout)
xlabel('Time (s)')
ylabel('Voltage (V)')
hold on
These are the comparations between PSIM results (red) and my code in MATLAB (blue). (For the capacitor discharge, I considered in both cases a initial voltage of 10V)
Open state:
Closed state:
Boost converter as in the code above:
I can never get steady state voltage superior than my input voltage (10V, in this case), but the waveform seems to consistent with each one of the states waveforms separately..
There must be an error in my code or am I missing some important point? Is this kind of solving possible?
Edited after answers:
Following the sugestions, I changed the second order differential equation into a system of two first order equations, in order to calculate the inductor's current, which is necessary because when the 'off state' begins, the inductors current must be a initial condition. In the previous model, I wasn't considering the current change on the 'on state'.
The 'off state' system:
\begin{equation} \begin{bmatrix} \frac{dV_{out}}{dt}\\ \frac{dI_{ind}}{dt} \end{bmatrix} = \begin{bmatrix} -\frac{1}{RC} & \frac{1}{C}\\ -\frac{1}{L} & 0 \end{bmatrix} \times \begin{bmatrix} V_{out}\\ I_{ind} \end{bmatrix} + \begin{bmatrix} 0\\ \frac{Vin}{L} \end{bmatrix} \end{equation}
The 'on state' system: (it's actually not a system, but I keep it matricial for simplicity)
\begin{equation} \begin{bmatrix} \frac{dV_{out}}{dt}\\ \frac{dI_{ind}}{dt} \end{bmatrix} = \begin{bmatrix} -\frac{1}{RC} & 0\\ 0 & 0 \end{bmatrix} \times \begin{bmatrix} V_{out}\\ I_{ind} \end{bmatrix} + \begin{bmatrix} 0\\ \frac{Vin}{L} \end{bmatrix} \end{equation}
There is still one problem. In this way, I can't prevent the inductor's current from being negative in the 'off state', so I inserted an if statement in every 'off state' iteration. If \$I_{ind} < 0\$, solve the system again imposing \$I_{ind} = 0\$. This can be made just setting to zero the elements related to \$I_{ind}\$ in the matrix.
Below are the result comparison (PSIM, first, MATLAB second) and the code.
R = 10;
L = 1e-3;
C = 1e-4;
Vin = 10; % DC input voltage
h = 1e-7; % step
sizeVector = 120000; % number of steps
X = zeros(2,sizeVector); % state vector
A = [-1/(R*C) 1/C ; -1/L 0]; % off state matrix
b = [0; Vin/L]; % off state vector
Aaux = [-1/(R*C) 0 ; 0 0]; % off state auxiliar matrix
baux = [0 ; 0]; % off state auxiliar vector
A2 = [-1/(R*C) 0; 0 0]; % on state matrix
b2 = [0; Vin/L]; % on state vector
D(D<0) = 0;
for k=2:sizeVector
if D(k) == 0 % off state
X(:,k) = (inv(eye(length(A)) - h*A))*(X(:,k-1) + h*b);
if X(2,k) < 0 % avoid Iind < 0
X(:,k) = (inv(eye(length(Aaux)) - h*Aaux))*(X(:,k-1) + h*baux);
end
end
if D(k) == 1 % on state
X(:,k) = (inv(eye(length(A2)) - h*A2))*(X(:,k-1) + h*b2);
end
end
figure(1)
plot(t,X(1,:))
hold on
plot(t,X(2,:))
xlabel('Time (s)')
ylabel('Voltage (V)\Current(A)')
legend('V_{out}','I_{in}')
ylim([-6 36])
grid
hold on
