i want to use a capacitor model in LTspice XVII. On the TDK webpage are a lot of models of their capacitors.
I chose the DC bias model (LTspice) of the C3216 commercial grade (up to 50V) C3216X5R1V226M160AC capacitor. After downloading the .rar file i extracted all models in my \LTspice\lib\sum\TDK\C3216 directory.
The .mod file is encrypted for LTspice. So i will not be able to read all specs of their capacitor, but i can use it as 'black box' model at least. The problem is that my LTspice is not able to open the .mod file. enter image description here
I don't know why! The first line of the .mod file says:
* LTspice Encrypted File * This encrypted file has been supplied by a 3rd * party vendor that does not wish to publicize * the technology used to implement this library. * Permission is granted to use this file for * simulations but not to reverse engineer its * contents.
In the file C3216X5R1V226M160AC.asy i found the line:
SYMATTR ModelFile C3216X5R1V226M160AC_b_LTspice.mod
So it should find the .mod file...
I am using LTspiceXVII on win10 x64.
    \$\begingroup\$ Where did you place the .mod file? If you placed it in Program Files (or wherever the default installation is), it won't work. XVII creates a second path in My Documents, though I wouldn't recommend. It may be better to simply extract them in the folder where your project resides. Placing the symbol is done through F2 > Top Directory drop-down menu. I just tried and it worked for me. If it's another cause, skip this. \$\endgroup\$ Commented Jan 17, 2018 at 8:38
  • \$\begingroup\$ You are right! The place where the .mod file is was the problem. The .mod files where placed in 'user\Documents\LTspiceXVII\lib\sym\myC'. Now i placed the .mod files in 'user\Documents\LTspiceXVII\lib\sub' and it works! Answer the question and i will mark it as solved! Thanks you \$\endgroup\$
    – sepplhans
    Commented Jan 17, 2018 at 14:07
  • \$\begingroup\$ Yeah, I agree, answers need to be answers not comments \$\endgroup\$
    – Voltage Spike
    Commented Jan 17, 2018 at 17:11
I'll just copy-paste my comment, if you say that did it. If it ain't broken...
