I just started doing electrical engineering as a hobby.
I want to build a circuit where a Micro-controller controls 300 LEDs. Those LEDs can draw a lot of power, so I use a larger power supply, which is quite inefficient when idling (3Watt Standby). This matters because the LEDs won't be on all the time. I will implement some kind of sensor which fires when I want light (like a button, human detection IR sensor, Bluetooth, ... ) and my idea was to use a second, more efficient power supply, which can power the controller as well as all sensors, but has not enough power for the LEDs. As soon the sensor fires, the micro-controller will activate a relay to activate the large power supply.
I am not quite sure if it is safe to use this layout, however, because I heard that you should not connect 2 power supplies in series. The LEDs get a DATA signal from my Micro-controller (which is on the efficient PS) while the LED is on the large PS.
I made a quick draft. Keep it in mind that I am no expert, so I might have made some errors.
  • Outlet: 230V 50Hz
  • PowerSupply1: 5V 2A
  • PowerSupply2: 5V 30A
  • Micro-controller: ESP32
  • LEDs: WS2812B
  • Data1: 3.3V < 10mA
  • Data2: 3.3V < 10mA
Edit1: I added a big blue wire connecting both grounds together like many suggested
    \$\begingroup\$ Sure, Just tie the Supply V- wires together. \$\endgroup\$
    – pgvoorhees
    Jan 16, 2018 at 12:59
  • \$\begingroup\$ You may need to make sure that Data is at 0 V when the Large Power Supply is off to avoid damaging the WS2812B (check the data sheet). Also, you should be able to find a suitable relay module by searching for "arduino 5v relay module". \$\endgroup\$ Jan 16, 2018 at 16:12
The power supplies you have illustrated are actually connected in parallel. This setup should be totally fine, and is in fact the defacto method of connecting circuits to the mains.
Consider how you may have multiple 5 V supplies plugged into a power strip. Each of these supplies would be connected to the same 2 nodes, live and neutral, and are therefore in parallel. They then convert the mains supply into the required format, in this case 5V.
Edit: here is an equivalent circuit you could use to visualise the connections. The two power supplies are referenced from the same ground node and should cause no problem to each other.
  • \$\begingroup\$ Afaik if i have 2 totally seperated circuts, there is no problem. However i worry about the Data signal from the ESP32 which is connected to the efficient power supply which will send a 3.3 volt signal to the LED, which is grounded on the large power supply. \$\endgroup\$
    – mac.1
    Jan 16, 2018 at 13:12
  • \$\begingroup\$ The power supply output grounds need to be tied together. Otherwise there is no circuit for the Data output from the microcontroller. \$\endgroup\$ Jan 16, 2018 at 13:13
  • \$\begingroup\$ Yes so long as they are reference from the same ground node you should be fine, see added schematic. \$\endgroup\$
    – loudnoises
    Jan 16, 2018 at 13:14
  • \$\begingroup\$ thank you. I updated my question and added a blue line between both grounds, will this now work ? \$\endgroup\$
    – mac.1
    Jan 16, 2018 at 13:20
  • \$\begingroup\$ Looks good to me :) \$\endgroup\$
    – loudnoises
    Jan 16, 2018 at 13:23
