-2
enter image description herehttps://www.partsim.com/embed/#102528
I made the following cirucit. Pin 1 2 and 3 are connected to microcontroller output pins. Pin 4 is where I want to measure a voltage. Only one pin (1,2,3) is high (3.3V) at a time.
My intend was to get 3 different voltages (pin 1 750mV, pin2 500mV, pin3 250mV). But of course this circuit does not work.
How could I achieve something like this?
Best Regards!
edit: I does not work because I get 0 V for Pin3 High, -250mV for Pin2 and 250mV for Pin1
Thank you all.
I did a combination of the suggestions of Eugene Sh an st2000. Took the resistor ladder with diodes to prevent current into the Pins.
  • \$\begingroup\$ Please embed your circuit into the question. \$\endgroup\$
    – Eugene Sh.
    Jan 16, 2018 at 16:15
  • \$\begingroup\$ sorry the link did not work. \$\endgroup\$
    – epgrape
    Jan 16, 2018 at 16:16
    \$\begingroup\$ You can augment it with opamp similar to this :ikalogic.cluster006.ovh.net/wp-content/uploads/8bitdac_2.jpg \$\endgroup\$
    – Eugene Sh.
    Jan 16, 2018 at 16:27
    \$\begingroup\$ how can you ask for this pin 1 750mV, pin2 500mV, pin3 250mV, when you have this Only one pin (1,2,3) is high (3.3V)? .... it is not clear what you are asking. \$\endgroup\$
    – jsotola
    Jan 16, 2018 at 16:42
    \$\begingroup\$ Suggestion: Study the Resistor Ladder page on Wikipedia. \$\endgroup\$
    – Finbarr
    Jan 16, 2018 at 17:04
My intend was to get 3 different voltages ... How could I achieve something like this?
Consider tying 4 resistors of known values together and measuring the voltage at that point. Connect 1 of the 4 resistors to ground. Connect the other 3 resistors each with a unique resistance to 3 different GPIO pins of the embedded processor. Most embedded processor GPIO pins are programmable as output-high, output-low & inputs. Program only 1 of the 3 different GPIO pins as an output-high. Program the other 2 as high impedance inputs. The measured voltage should reflect the voltage divider created between the pin configured as an output-high and ground through the 2 resistors which make up the divider. Repeat this pattern for the other 2 GPIO pins. The voltage should be unique for each of the 3 GPIO pins if you have chosen 3 unique resistor values for the resistors connected to the GPIO pins.
If the embedded processor is not capable of programming pins as high impedance inputs, add a diode in series with each of the 3 resistors already attached to the 3 different GPIO pins. Arrange the diode such that the Anode is closest to the GPIO pin. Now when 1 of the 3 GPIO pins is programmed to the high state that pin's diode will be forward biased and will influence the measured voltage where all the resistors converge. The other 2 GPIO pins are programmed to the low state and the connected diodes will be in reversed bias and will not allow current to flow. Therefore the other 2 GPIO pins will not influence the measured voltage where all the resistors converge. Program a different GPIO pin high while all other GPIO pins are low and epeat the voltage measurement. Do this for each GPIO pin.
  • \$\begingroup\$ @egrape: Note that any load you apply to the mid-point of a voltage divider will be seen as an additional resistor in parallel with the bottom resistor, so will affect the voltage at that point. If the top resistor is a high value, like 200K, you can only draw a tiny current from the voltage divider without making a significant change in the output voltage. \$\endgroup\$ Jan 16, 2018 at 16:43
  • \$\begingroup\$ I do not have the possibility to change the Pin Direction unfortunatly. \$\endgroup\$
    – epgrape
    Jan 16, 2018 at 16:51
  • \$\begingroup\$ @epgrape, you can add a diode to each digital output pin that is forward biased when the pin is high and reversed biased when the pin is low. I can add this to my answer if you wish. \$\endgroup\$
    – st2000
    Jan 17, 2018 at 4:30
