Dear Group Members,
I have a question which might have been asked before, but I couldn't find the suitable answer for my application, due to which I need more help in my case.
my uC with 3,3V logic is required to turn ON the N-channel Mosfet (as a safety measure, that means Mosfet will operate only in error conditions and not with a certain frequency) which has different reference potential point as compared to uC's Ground (GND). In my Opinion, I cant overload my uC with source and sink currents of Mosfet (might be around 700mA - 1.5A depending on Mosfet), and I think I would need the same reference potential as that of Mosfet to turn it on. The reference potential of Mosfet is shown with small triangle symbol with OpAmp which has same voltage references as that of Mosfet.
In the shown circuit, I have a plan to pull up the GPIO to turn OFF the Mosfet (nearly -5V at Gate of Mosfet, Rail to Rail OpAmp) and pull down the GPIO to turn ON the Mosfet (nearly 0V at Gate of Mosfet).
My question is if this solution is elegant and if it will work as expected or maybe I am missing any detail. In other case, any other more elegant solution will be highly appreciated. Priority is to have a small size and less costly solution.
Note: the microcontroller 3,3V logic is generated with an LDO supplied with reference voltage point of Mosfet (0V) and -5V. That means microcontroller ground (GND) is same as -5V point of Mosfet.
EDIT_1: Resistor R2 moved from Mosfet Source to Gate Side as Pull Down
EDIT_2: 3.3V LDO added
