To check the synthesisability of while loop, I created one hypothetical vhdl code as follows.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.all;
entity test_loop is
Port ( a : in INTEGER;
i : in INTEGER;
CLK : in std_logic;
b : out unsigned (3 downto 0));
end test_loop;
architecture Behavioral of test_loop is
--signal C : unsigned (3 downto 0) := "0000";
begin
process(CLK)
variable C : unsigned (3 downto 0) := "0000";
begin
if (rising_edge(CLK)) then
while(a /= i ) loop
C := C + 1;
end loop;
b <= C;
end if;
end process;
end Behavioral;
I was expecting a synthesising error because I think the loop has no definite bounds. I cant simulate this code too because it goes infinite for a /= i . But surprisingly this code got synthesised in Xilinx 13.1 ISE without showing errors. What might be the reason ?
UPDATED:
changed C into variable. Still the code is getting synthesised. RTL view is obtained as -
