I'm trying to solve for \$I_{copy}\$, but I've looked around on the internet and cannot find an explanation. However, I know the formula:
\$ I_{copy} =\frac{I_{REF} * W_1/L_1}{W_{REF}/L_{REF}}\$
but don't understand how to work this out from the circuit diagram.
Attached is an image explanation my problem. Answer for:
  • The circuit on the left: \$I_{copy}=\frac{2}{8I_{REF}}\$
  • The circuit on the right: \$I_{copy}= 7I_{REF}\$
1]
Your formula is for one current mirror. You could use it to determine the current through the NMOS marked 2(W/L)n in the left circuit.
That current would then be 2/3 * Iref.
That same current is fed into a 2nd current mirror, the one with 2 PMOS transistors. Use the same formula again but note what the input current is: 2/3 Iref
The right schematic is slightly more complex but using the formula you can determine the currents through the NMOS marked 5(W/L)n and 3(W/L)n.
Then again solve the currents in the PMOS mirror.
At the output what happens to those 2 currents? Use the current law if you must.
