7
I know we can do that in Eagle by selecting a block and copying them. Has Ki cad Implemented such feature? It documentation says I need to hold "SHIFT" Key and select to copy. Doesn't Work!!
Application: kicad Version: 4.0.7 release build wxWidgets: Version 3.0.3 (debug,wchar_t,compiler with C++ ABI 1011,GCC 7.1.0,wx containers,compatible with 2.8) Platform: Windows 8 (build 9200), 64-bit edition, 64 bit, Little endian, wxMSW Boost version: 1.60.0 Curl version: libcurl/7.54.1 OpenSSL/1.0.2l zlib/1.2.11 libssh2/1.8.0 nghttp2/1.23.1 librtmp/2.3 USE_WX_GRAPHICS_CONTEXT=OFF USE_WX_OVERLAY=OFF KICAD_SCRIPTING=ON KICAD_SCRIPTING_MODULES=ON KICAD_SCRIPTING_WXPYTHON=ON USE_FP_LIB_TABLE=HARD_CODED_ON BUILD_GITHUB_PLUGIN=ON
It should. If it doesn't, that's definitely a bug.
As an alternative, select with your mouse, right-click and go to "Save", which is KiCad 4's way of saying "Copy". Then use the paste icon to insert a copy of the block you selected.
-- Addendum --
It occurs to me that you might be holding SHIFT and clicking to copy an item. KiCad only supports the idea of copying a block of items. You would need to hold SHIFT and then click+drag to select and copy the items. To duplicate a single item, you need to use the SHIFT and click+drag action but only allow the selection box to cover a single item.
    \$\begingroup\$ Reboot solved the issue! I don't know how. #Windows lol \$\endgroup\$
    – MaNyYaCk
    Jan 19, 2018 at 4:40
  • \$\begingroup\$ this is not working in kiCad 5.1.10 \$\endgroup\$ Nov 3, 2021 at 11:17
First: make a block by driving the mouse about the area to copy. Press the left mouse key and mark the area. Second: press Ctrl + c to copy this area Third: press Ctrl + v to insert the marked area and place the copy.
  • \$\begingroup\$ this only works inside the same PCB layout , and not between 2 different PCB layouts \$\endgroup\$ Nov 3, 2021 at 11:18
-1
Press and hold "G" key (in KiCad it performs Grab/Move) while left click and hold mouse button to draw a selection rectangle around items. Pheww it was hard to write/describe wasn't it?
