I'm having trouble identifying a blown SMD tantalum capacitor. The markings on it are 10 35L which I took to be the capacitance, voltage rating, and tolerance, but looking up that component on the schematic provided with it, that same component is labeled with the value 47U/16V. As this capacitor blew after being subjected to a 13 VDC power supply for an extended period of time instead of the 9 VDC the board is rated at, a 16 volt rating seems more likely than 35 volts. A neighboring cap has the label 220-10L which more closely matches the schematic for it's value which is listed as 220U/6.3V. This makes me wonder if I have a different revision of the schematic than the board or if the labeling is using a different scheme. What's the value of the capacitor I need to replace it with?
Blown Capacitor
  • \$\begingroup\$ Well, you have a choice; either believe the capacitor markings, believe the circuit or do some research. \$\endgroup\$
    Jan 19, 2018 at 10:11
  • \$\begingroup\$ @andy my main concern was whether I was interpreting the markings correctly. It sounds like I am, though I can't seem to find L on any table of tolerance codes so far. \$\endgroup\$
    – penguin359
    Jan 19, 2018 at 21:48
Generally you are right that per marking it should be 10uF/35V capacitor. You did not state who the manufacturer is, they may simply have used gray market to source cheap remarked components.
I recommend you contacting developer/manufacturer with question about deviation in the board and circuit, not telling about voltages you applied. Because as soon as they will hear about your doubts and special conditions, they may immediately state that it is not warranty case and that it is your fault, proposing repair on T&M basis.
Hear their answer first (append info from them to your question), and then decide what to do.
P.S. If developer and manufacturer are different entities, then developer may not know what manufacturer is doing, thus raising quality issue would be a good action towards developer and your peer users of this product.
  • \$\begingroup\$ The development board manufacturer is Terasic, but I actually purchased an older model of the board from a seller on eBay since the price on a new board was a bit steep. The 13 volt wall wart, which I neglected to read carefully, was the power source the eBay seller provided. The schematic came from the same source so I have a little less trust in it now. \$\endgroup\$
    – penguin359
    Jan 19, 2018 at 21:43
  • \$\begingroup\$ Find image of the board on the internet to see if others are having the same caps. And, if it's worth, ask eBay seller several tough questions. \$\endgroup\$
    – Anonymous
    Jan 19, 2018 at 21:51
the 220-10L is a vishay [email protected] (10V surge) the other part, the 10 35L is most likely a Chinese copy of a vishay capacitor (that might be sold as various brands, like xicon) 10uf @20V (35v surge)
You always have to keep in mind its surge and when design with these capacitors. They have a tendency to short out with inrush current. These are my least favorite caps to build with because they don't have a good longevity compared to normal electrolytic capacitors. Only suitable for throw away devices, and even then, I don't like them because most stuff that get them get thrown away and arsenic (the primary chemical in them) is poisonous to the ground water. People really need to look at the environmental impact they do when it comes to this, regardless how cheaper they are.
I just identified a similar capacitor, Vishay part 293D.
Mine had code 47-6 L5 (2) [see picture]. According to a Vishay rep, the L in my case is part of a date code that was used in 1999 and 2019. Mine had an L5 on it, meaning May of 1999. The circle 2 is the plant mark for the Sanford ME plant.
However, looking at the data sheet for the 293D at https://www.vishay.com/docs/40002/293d.pdf, it looks like when L is in the upper right, as in your case, it is used to denote that it is lead free.
For folks trying to identify similar capacitors, I had luck emailing [email protected]
Image: Photo of capacitor mentioned
  • \$\begingroup\$ The Vishay rep said it might also be a part 593D, the identical low ESR version \$\endgroup\$
    – Ryan S.
    Apr 28, 2022 at 20:40
