Below is a floating source is coupled to a instrumentation amplifier via a twisted shielded cable:
For the sake of showing effects to some people by simulation, I want to add a common mode voltage, a magnetic coupling effect and capacitive coupling effect to the cable to mimic the real scenario. So far I tried to add a common mode as below:
How can the final circuit be modified so that magnetic and capacities coupling also demonstrated?
Edit:
Is this model correct:
Edit2 enter image description here
Edit3 enter image description here
Edit4
  • \$\begingroup\$ perhaps you can calculate some rough numbers on the amount of coupling you expect, and then model this with lumed capacitors and coupled inductors? \$\endgroup\$
    – Joren Vaes
    Jan 19, 2018 at 10:13
  • \$\begingroup\$ I mean the numbers doesn't matter but I dont know the toplogy to simulate. Btw it doesnt have to be complicated like with inductors caps if hard. It would be enough if I can add noise with a voltage and current source on that STP cable. \$\endgroup\$
    – GNZ
    Jan 19, 2018 at 10:16
  • \$\begingroup\$ just adding some capacitance between the two lines could be enough to simulate coupling effects. But keep in mind that you are modeling just one differential line, which won' t suffer from capacitive coupling in the classic sense (crosstalk) but rather just see a capacitor that might lower it's bandwidht. Capacitive coupling causing crosstalk is a problem when you have multiple pairs that carry different signals, and the signal of one pair "leaks" into another. \$\endgroup\$
    – Joren Vaes
    Jan 19, 2018 at 10:19
  • \$\begingroup\$ That's why I need a more comprehensive model. A model with common mode, magnetic and capacitive coupling. I dont for instance know if I add a noise source it also has to be added to the shield line. \$\endgroup\$
    – GNZ
    Jan 19, 2018 at 10:21
  • \$\begingroup\$ In my case Im not sure there would be cross talk. It is just one cable STP 10 meters far from other cables. Cable has 1 pair 1 shiled. \$\endgroup\$
    – GNZ
    Jan 19, 2018 at 10:22
You can add interfering magnetic coupling to each line by using three inductors and a coupler called "k". Two inductors are placed in series with each line and the third is driven by an independant source of the noise or interference. "k" is a component in all spice tools and it defines the coupling factor (0 to 1) between the driven inductor and the two series inductors. That is how I have done noise coupling in the past.
Inductor values should be tens of nano henry to hundreds of nano henry typically for this type of simulation.
Capacitive coupling requires a capacitor from each line to a driven point. The driven point is a voltage source of interference to ground.
As with both of the above if the impedance in each line (or connected to each line) is slightly different you get a differential coupling as well as a common mode coupling.
  • \$\begingroup\$ Thanks for the answer I will try these. But there is two things maybe you might comment on: 1-) At least is my model for common mode voltage correct? If so I will keep it. 2-) As you see the amplifier is an inAmp and as far as I underatnd since the inAmp has huge input impedance output resistances need not to be equal becuase source to ground resistance for each line is dominated by the buffers of the inAmp. If correct why is twisted cable used. If the line impedance are dominated by the inAmp and we dont care about the source impedance why we care about twistng? \$\endgroup\$
    – GNZ
    Jan 19, 2018 at 10:59
  • \$\begingroup\$ Thats why I want to simulate and see if magnetic imbalance has effect on the output. \$\endgroup\$
    – GNZ
  • \$\begingroup\$ 1) your model is fine. 2) You need to model line capacitance so you should use maybe 50 - 100 pF per metre lumped and these will dominate over InAmp input impedance. 3) Twists are used to cancel out a magnetic field trying to impegnate the cable; in effect the only net induced voltage is that over the area bounded by one twist. This is a big subject and well beyond the scope of the original question and there are plenty of answers to this on this site. \$\endgroup\$
    Jan 19, 2018 at 11:12
  • \$\begingroup\$ Oh I think I got what you mean. For 10 meters capacitance becomes 1000pF which means from 1/(2*pi'f*C) and if 50Hz reactance Xc becomes like 3MegOhm. So this means to me output resistance of the source can be neglected by dominance of the buffers but we cant neglect the capacitive imbalance. I hope I understand what you meant (?) \$\endgroup\$
    – GNZ
    Jan 19, 2018 at 12:05
  • \$\begingroup\$ Please also see my edit. I tried to draw what you mentioned as lumped model for the magnetic and cap coupling. C1 C2 C3 are for cap coupling. L1 L2 L3 are coupled via L4. Is this better? \$\endgroup\$
    – GNZ
    Jan 19, 2018 at 12:11
