I would like to buy a small digital volt-panel-meter. My eye fell on this series from Murata:
DMS-20LCD (https://www.murata-ps.com/data/meters/20lcd.pdf)
This meter can be powerd by either a 5V supply or 9V battery.
The datasheet limits the Common Mode Voltage Range to +/-2V on the second page, but no further explanation is given. Page 4 in the datasheet mentions the Common Mode Voltage again in the first application example:
When I see the picture, I would say:
  • Vcm = 2.5V
  • Vin- = 2.5V - 0.833V
  • Vin+ = 2.5V + 0.833V
Since Vcm = 2.5V, it is outside the +/-2V range. Why would Murata give an example which doesn't meet its own specs? I'm clearly missing something here.
I see your dilemma. Firstly, yes, you are quite right that strictly-speaking, the common mode voltage on the diagram is 2.5 volts but you could also make an argument that it is 1.667 volts with a signal of +1.667 volts on pin 11.
I think this is what they mean although by no means is this clear in their document. In other words, make sure pin 12 remains within +/-2 volts if you want accuracy.
  • \$\begingroup\$ Thank you sir. Their document is so ... unclear :-(. So pin 12 should remain within +/- 2 volts. What are the limits on pin 11? \$\endgroup\$
    – K.Mulier
    Commented Jan 19, 2018 at 14:05
  • \$\begingroup\$ That is how I read the situation. If your meter has a +/- 200 mV range then pin 11 has to be within +/-200 mV of pin 12 or you will reach full-scale limitations. It won't damage the device but you run out of measurement capability. If your input can measure +/- 200 volts then pin 11 can be as high as 202 volts or as low as -202 volts at extremes of the limitation imposed on pin 12. \$\endgroup\$
    Commented Jan 19, 2018 at 14:07
  • \$\begingroup\$ Oh, okay. Thank you sir. You seem to have lots of experience (almost 200k)! Which panel meter would you suggest? I need 6 small panel meters, preferably ones that I can solder on a board :-). They need to measure the voltages of Li-ion cells (6 serial connected cells). \$\endgroup\$
    – K.Mulier
    Commented Jan 19, 2018 at 14:09
  • \$\begingroup\$ I'm building a test-setup, and need to keep an eye on all the individual cell voltages :-) \$\endgroup\$
    – K.Mulier
    Commented Jan 19, 2018 at 14:10
  • \$\begingroup\$ I have NO experience of panel meters! I've never used one or chosen one. \$\endgroup\$
