“That won't use much much LUT logic though. Nor test any other embedded blocks like BRAMs and DSPs.”
I think making a massive shift register with alternating ones and zeros is an elegant solution. If you play your cards right and avoid explicit sets/resets or directly making use of individual bits, the synthesizer may infer that it can make use of tight SRL-based (LUT-based) shift registers to save space, but you can also explicitly request SRL-based shift registers by making use of SRL16E or SRLC32E library primitives to build up a larger structure. Furthermore, if you cut things up into 34-bit shift register pieces, you’ll be able to make your structure thread through all of the available LUTs and FFs quite nicely, as suggested by the Verilog code snippet below which will fit snugly inside precisely one Spartan-6 or 7-series slice:
wire [4:0] bits; // Shift interconnect: 0->1->2->3->4
SRL16E #(.INIT(16'hAAAA)) // First 16-bit LUT-based shift register
srl1 (
.CLK(clock),
.CE(1'b1),
.A3(1'b1), .A2(1'b1), .A1(1'b1), .A0(1'b1),
.D(bits[0]),
.Q(bits[1])
FDE #(.INIT(1'b1)) // First 1-bit FF-based shift register
fde1 (
.C(clock),
.CE(1'b1),
.D(bits[1]),
.Q(bits[2])
SRL16E #(.INIT(16'h5555)) // Second 16-bit LUT-based shift register
srl2 (
.CLK(clock),
.CE(1'b1),
.D(bits[2]),
.Q(bits[3])
FDE #(.INIT(1'b0)) // Second 1-bit FF-based shift register
fde2 (
.C(clock),
.CE(1'b1),
.D(bits[3]),
.Q(bits[4])
XAPP52 "Efficient Shift Registers, LFSR Counters, and Long Pseudo-Random Sequences Generators" has several examples of this approach.
For more general info about SRL16E and SRLC32E, consult:
UG768 "Xilinx 7 Series FPGA Libraries Guide for HDL Designs"
UG615 "Spartan-6 Libraries Guide for HDL Designs".
To pull in RAM blocks and DSPs you would need additional circuitry, possibly feeding collections of shift register feeds to seed them with data that is constantly changing. Dual-ported RAM blocks could be used to build up a large FIFO chain that is 1-bit wide and N-stages deep (depending on the resources available in your FPGA). Thus, you could use the RAM blocks to extend your shift register chain to truly epic lengths.
