-2
This IC must be a timer which is found in a flowmeter. Can anyone help me identify it.
Things written on it are 397C1 3310D 1611CM
    \$\begingroup\$ Why do you think "it must be a timer"? It's much more likely to be an MCU. \$\endgroup\$ – Transistor Jan 20 '18 at 7:00
  • \$\begingroup\$ Related: electronics.stackexchange.com/questions/334128/… \$\endgroup\$ – Voltage Spike Jan 20 '18 at 7:22
  • \$\begingroup\$ Those 'JTAG pins' are badly soldered (at least that's what I presume them to be) \$\endgroup\$ – Voltage Spike Jan 20 '18 at 7:25
    \$\begingroup\$ @laptop2d Could those be press-fit connectors? I've never seen them personally, so just a wild guess ;) \$\endgroup\$ – AdrianoKF Jan 20 '18 at 9:41
    \$\begingroup\$ Next time try typing the numbers into google. It came up first hit.... \$\endgroup\$ – Trevor_G Jan 20 '18 at 12:52
9
It's a nordic semiconductor bluetooth chip. I don't know exactly which one, but if you want you can look through all their datasheets to find the product markings, and one of them will match up. There's also a chip antenna at the top of the picture.
  • \$\begingroup\$ Is it really a chip antenna? Looks to me like one of these 32-ish kHz crystal packages. Its placement also doesn't scream antenna to me. \$\endgroup\$ – Richard the Spacecat Mar 28 '18 at 7:40
