I built the following simple circuit as an input to an ESP8266 microcontroller:
When I hold the switch closed, the input goes low. How do I modify this circuit to do the opposite? I want to press a switch to produce a high signal for the input to the microcontroller.
  • \$\begingroup\$ if you use INPUT_PULLUP, you only need the switch+ground+GPIO: no resistor or vcc \$\endgroup\$ – dandavis Jan 26 '18 at 5:57
  • \$\begingroup\$ @dandavis Thanks. Can you write that up as an answer? \$\endgroup\$ – Code-Guru Jan 26 '18 at 6:23
  • \$\begingroup\$ it doesn't answer the question asked as well as the given one, but glad to help. \$\endgroup\$ – dandavis Jan 26 '18 at 6:26
  • \$\begingroup\$ @dandavis It still answers the question that I didn't even know to ask. \$\endgroup\$ – Code-Guru Jan 26 '18 at 6:35
You can do this:
| improve this answer | |
  • \$\begingroup\$ Of course! I need some resistance on the ground circuit to force the current from the source to go to the I/O connection. Thanks! \$\endgroup\$ – Code-Guru Jan 21 '18 at 18:09
    \$\begingroup\$ It would be better to change the GPIO to pull-down as well. \$\endgroup\$ – Spehro Pefhany Jan 21 '18 at 18:27
