-1
I would like to write an internal reg to a txt file.
I have tried something like:
    f = $fopen("conv2_tb_output.txt","w");
    $fmonitor(f, value=%d\n", mat_out);
    $fclose(f);
But since mat_out is an internal reg, I got an error: is not declared.
Does anyone body know how to write internal regs to a txt file?
Thanks in advance
I presume you're trying to access a register inside a module from a testbench that instantiates that module. In this case, I think what you need to do is use a hierarchical reference. Instead of using mat_out, use module_instance_name.mat_out where module_instance_name is the name of the instance of the module that contains mat_out.
| improve this answer | |
  • \$\begingroup\$ That's it. Now I don't get any error, but conv2_tb_output.txt does not contain anything. I have to say that mat_out is a matrix. edaplayground.com/x/6G7h# \$\endgroup\$ – user204415 Jan 22 '18 at 9:22
  • \$\begingroup\$ Try it with a simple integer and see if that works. Or try accessing a single element of the matrix. You may need to do a bit more work to print out a whole matrix (i.e. you may need to use a for loop and iterate over it). \$\endgroup\$ – alex.forencich Jan 22 '18 at 9:34
    \$\begingroup\$ Also, maybe try closing the file at the end of the testbench instead of immediately after opening it. \$\endgroup\$ – alex.forencich Jan 22 '18 at 9:36
  • \$\begingroup\$ It's really weird, but, if after $fmonitor(f, "time=%5d, valor=%d\n", $time, uut.mat_out); I write anything like: $fmonitor(f, "time=%5d, valor=%d\n", $time, uut.mat_out); fdsfdsfdfsd. The simulation fails but the txt file contains mat_out!!! Can you explain that? lol \$\endgroup\$ – user204415 Jan 22 '18 at 9:56
