-2
  • Is it true that NeoPixels are used in Amazon Echo series?
  • If so how many NeoPixel LED's are used?
  • If so what are the optics used to give a smooth streak of colours?
closed as off-topic by pipe, RoyC, Voltage Spike, PeterJ, Andy aka Jan 26 '18 at 17:07
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – pipe, RoyC, Voltage Spike, PeterJ, Andy aka
If this question can be reworded to fit the rules in the help center, please edit the question.
No, NeoPixel LEDs are not used, they use custom LEDs, then a circular strip of opaque plastic is used to diffuse the light from the individual LEDs. There are twelve LEDs on the Echo.
  • \$\begingroup\$ By custom do you mean a some other brand than NeoPixel, or the in-house made LED's by Amazon? \$\endgroup\$ – iamnagaky Jan 23 '18 at 8:23
  • \$\begingroup\$ @iamnagaky They have SMD LEDs directly attached to one of the three circuit boards. \$\endgroup\$ – skillz21 Jan 23 '18 at 8:50
  • \$\begingroup\$ @iamnagaky I think s/he just means plain RGB LEDs with no fancy control stuff. \$\endgroup\$ – immibis Aug 22 '18 at 2:02
