The above problem was asked in a test. I got the wrong answer because I solved it in the following way.
BW without FB = 1000 - 100 = 900
BW with FB = BW without FB * (1+A*beta) = 900 * 100 = 90kHz
I understand that both both the formulae are different and both can't be right at the same time. But my book mentions below 3 formulae bcz of which I got confused in the test.
fH with FB = fH without FB * (1+A*beta)
fL with FB = fL without FB / (1+A*beta)
Please guide me on this, which formulae to use ?
If the amplifier is capacitively coupled this affects the lower frequencies that can pass. As originally quoted the low frequency cut-off point is 100 Hz and this is where I have a problem with the solution. No matter what extra applied feedback is introduced, that LF cut-off is going to remain at 100 Hz.
Think of an inverting op-amp configuration: -
The LF cut-off is dictated by C and R1 attached to the inverting input (a virtual earth) and you can reduce R2 as much as you want and it won't alter this fact.
How about a non-inverting amplifier: -
In this type of amplifier the LF cut-off is defined by C and Rbias and no amount of fiddling with R1 and R2 is going to alter this.
So, for the amplifiers I have shown above, the LF cut-off remains at 100 Hz.
For the HF cut-off, if the gain is reduced (by feedback) from 1000 (60 dB) to 10 (20 dB) and it is assumed that the gain-roll-off slope is 6 dB per octave (20 dB per decade) then you get a new HF cut-off of 100 kHz: -
  • \$\begingroup\$ These guys ask just formula-based questions with no relation to the practical world. \$\endgroup\$ – Nikhil Kashyap Jan 22 '18 at 10:54
  • \$\begingroup\$ @NikhilKashyap it is a badly conceived problem in my book and no-matter how hard I think, I can't see any scenario where LF cut-off is going to be affected. \$\endgroup\$ – Andy aka Jan 22 '18 at 12:04
  • \$\begingroup\$ If the low-freq cutoff were INSIDE THE LOOP, behavior would change. \$\endgroup\$ – analogsystemsrf Jan 23 '18 at 19:09
  • \$\begingroup\$ @analogsystemsrf yeah I know but can you think of a configuration like this? \$\endgroup\$ – Andy aka Jan 23 '18 at 19:16
