I'm getting the error "[Synth 8-2519] partially associated formal q8 cannot have actual OPEN" - this error is for the line Q8(0) => OPEN, and all similar OPEN assignments. I'm using these because the IN_FIFO element is too large for the data I want to send through it.
The full entity instantiation is below for context (sorry about the large code below, it's just a large set of assignments).
IN_FIFO_LVDS_A_inst : IN_FIFO
generic map (
  ALMOST_EMPTY_VALUE  => 1,                   -- Almost empty offset (1-2)
  ALMOST_FULL_VALUE   => 1,                   -- Almost full offset (1-2)
  ARRAY_MODE          => "ARRAY_MODE_4_X_4",  -- ARRAY_MODE_4_X_8, ARRAY_MODE_4_X_4
  SYNCHRONOUS_MODE    => "FALSE"              -- Clocks synchronous to each other (FALSE)
port map (
-- FIFO Status Flags: 1-bit (each) output: Flags and other FIFO status outputs
ALMOSTEMPTY => ALMOSTEMPTY_LVDS_S,      -- 1-bit output: Almost empty
ALMOSTFULL  => ALMOSTFULL_LVDS_S,       -- 1-bit output: Almost full
EMPTY       => EMPTY_LVDS_S,            -- 1-bit output: Empty
FULL        => FULL_LVDS_S,             -- 1-bit output: Full
-- Q0-Q9: 8-bit (each) output: FIFO Outputs
Q0(0) => a_line_lvds_i_1_sync_s(13) , -- output: Channel 0
Q0(1) => a_line_lvds_i_1_sync_s(12) ,
Q0(2) => a_line_lvds_i_1_sync_s(11) ,
Q0(3) => a_line_lvds_i_1_sync_s(10) ,
Q1(0) => a_line_lvds_i_1_sync_s(9)  , -- output: Channel 1
Q1(1) => a_line_lvds_i_1_sync_s(8)  ,
Q1(2) => a_line_lvds_i_1_sync_s(7)  ,
Q1(3) => a_line_lvds_i_1_sync_s(6)  ,
Q2(0) => a_line_lvds_i_1_sync_s(5)  , -- output: Channel 2
Q2(1) => a_line_lvds_i_1_sync_s(4)  ,
Q2(2) => a_line_lvds_i_1_sync_s(3)  ,
Q2(3) => a_line_lvds_i_1_sync_s(2)  ,
Q3(0) => a_line_lvds_i_1_sync_s(1)  , -- output: Channel 3
Q3(1) => a_line_lvds_i_1_sync_s(0)  ,
Q3(2) => a_line_lvds_i_0_sync_s(17) ,
Q3(3) => a_line_lvds_i_0_sync_s(16) ,
Q4(0) => a_line_lvds_i_0_sync_s(15) , -- output: Channel 4
Q4(1) => a_line_lvds_i_0_sync_s(14) ,
Q4(2) => a_line_lvds_i_0_sync_s(13) ,
Q4(3) => a_line_lvds_i_0_sync_s(12) ,
Q5(0) => a_line_lvds_i_0_sync_s(11) , -- output: Channel 5
Q5(1) => a_line_lvds_i_0_sync_s(10) ,
Q5(2) => a_line_lvds_i_0_sync_s(9)  ,
Q5(3) => a_line_lvds_i_0_sync_s(8)  ,
Q6(0) => a_line_lvds_i_0_sync_s(7)  , -- output: Channel 6
Q6(1) => a_line_lvds_i_0_sync_s(6)  ,
Q6(2) => a_line_lvds_i_0_sync_s(5)  ,
Q6(3) => a_line_lvds_i_0_sync_s(4)  ,
Q7(0) => a_line_lvds_i_0_sync_s(3)  , -- output: Channel 7
Q7(1) => a_line_lvds_i_0_sync_s(2)  ,
Q7(2) => a_line_lvds_i_0_sync_s(1)  ,
Q7(3) => a_line_lvds_i_0_sync_s(0)  ,
Q8(0) => OPEN                       , -- output: Channel 8
Q8(1) => OPEN                       ,
Q8(2) => OPEN                       ,
Q8(3) => OPEN                       ,
Q9(0) => OPEN                       , -- output: Channel 9
Q9(1) => OPEN                       ,
Q9(2) => OPEN                       ,
Q9(3) => OPEN                       ,
-- D0-D9: 4-bit (each) input: FIFO inputs
D0(0) => a_line_lvds_i_1_s(13)      ,  -- input: Channel 0
D0(1) => a_line_lvds_i_1_s(12)      ,
D0(2) => a_line_lvds_i_1_s(11)      ,
D0(3) => a_line_lvds_i_1_s(10)      ,
D1(0) => a_line_lvds_i_1_s(9)       ,  -- input: Channel 1
D1(1) => a_line_lvds_i_1_s(8)       ,
D1(2) => a_line_lvds_i_1_s(7)       ,
D1(3) => a_line_lvds_i_1_s(6)       ,
D2(0) => a_line_lvds_i_1_s(5)       ,  -- input: Channel 2
D2(1) => a_line_lvds_i_1_s(4)       ,
D2(2) => a_line_lvds_i_1_s(3)       ,
D2(3) => a_line_lvds_i_1_s(2)       ,
D3(0) => a_line_lvds_i_1_s(1)       ,  -- input: Channel 3
D3(1) => a_line_lvds_i_1_s(0)       ,
D3(2) => a_line_lvds_i_0_s(17)      ,
D3(3) => a_line_lvds_i_0_s(16)      ,
D4(0) => a_line_lvds_i_0_s(15)      ,  -- input: Channel 4
D4(1) => a_line_lvds_i_0_s(14)      ,
D4(2) => a_line_lvds_i_0_s(13)      ,
D4(3) => a_line_lvds_i_0_s(12)      ,
D5(0) => a_line_lvds_i_0_s(11)      ,  -- input: Channel 5
D5(1) => a_line_lvds_i_0_s(10)      ,
D5(2) => a_line_lvds_i_0_s(9)       ,
D5(3) => a_line_lvds_i_0_s(8)       ,
D5(4) => '0'                        ,
D5(5) => '0'                        ,
D5(6) => '0'                        ,
D5(7) => '0'                        ,
D6(0) => a_line_lvds_i_0_s(7)       ,  -- input: Channel 6
D6(1) => a_line_lvds_i_0_s(6)       ,
D6(2) => a_line_lvds_i_0_s(5)       ,
D6(3) => a_line_lvds_i_0_s(4)       ,
D6(4) => '0'                        ,
D6(5) => '0'                        ,
D6(6) => '0'                        ,
D6(7) => '0'                        ,
D7(0) => a_line_lvds_i_0_s(3)       ,  -- input: Channel 7
D7(1) => a_line_lvds_i_0_s(2)       ,
D7(2) => a_line_lvds_i_0_s(1)       ,
D7(3) => a_line_lvds_i_0_s(0)       ,
D8(0) => '0'                        ,  -- input: Channel 8
D8(1) => '0'                        ,
D8(2) => '0'                        ,
D8(3) => '0'                        ,
D9(0) => '0'                        ,  -- input: Channel 9
D9(1) => '0'                        ,
D9(2) => '0'                        ,
D9(3) => '0'                        ,
-- FIFO Control Signals: 1-bit (each) input: Clocks, Resets and Enables
RDCLK => clk_150MHz_thruline_s      , -- 1-bit input: Read clock
RDEN  => '1'                        , -- 1-bit input: Read enable
RESET => bus_a_reset_pl(1)          , -- 1-bit input: Reset
WRCLK => dclk_a_pll_clk0            , -- 1-bit input: Write clock
WREN  => '1'                          -- 1-bit input: Write enable
I'm confused as to why the synthesiser in Vivado complains about this - surely I can set unused outputs to OPEN and unused inputs to '0'. Is there something special about the IN_FIFO?
  • \$\begingroup\$ Only had a quick glance but have you tried connecting your unused I/O to signals, leaving the unused output signals unconnected and tying the unused input signals to zeroes? \$\endgroup\$ – TonyM Jan 22 '18 at 11:31
    \$\begingroup\$ Weirdly, setting the whole of Q8 => OPEN, instead of Q8(0) => OPEN, Q8(1) => OPEN,... etc seems to have got rid of the warning message. Apparently Vivado synthesis hates setting individual lines to open despite the fact that the code logically does the same thing?! \$\endgroup\$ – BenAdamson Jan 22 '18 at 11:54
  • \$\begingroup\$ Saw that, thanks, upvoted @scary_jeff 's good answer and filed it away - am using Vivado on a forthcoming project. \$\endgroup\$ – TonyM Jan 22 '18 at 12:04
6
In VHDL, you cannot connect an individual element of a port to open. You must connect either the whole port to open, or connect some elements to your intended signals, and others to 'dummy' unused signals.
So you have a couple of options:
Q8 => open, -- Just associate the whole port with `open`
if for some reason you must use individual association:
signal unused_q8 : std_logic_vector(3 downto 0);
Q8(0) => unused_q8(0),
Q8(1) => unused_q8(1),
Q8(2) => unused_q8(2),
Q8(3) => unused_q8(3),
The more common scenario in which you would see this error message would look like:
Q8(2 downto 0) => q8_out(2 downto 0),
Q8(3) => open,
Here we have associated some elements of an output vector with a signal, and others with open. This is not supported.
  • \$\begingroup\$ Thanks - I managed to stumble upon this for myself a second ago. It's pretty weird that Vivado doesn't permit this use of OPEN. Good explanation! \$\endgroup\$ – BenAdamson Jan 22 '18 at 11:56
  • \$\begingroup\$ All synth tools have some quirks. With a relatively harmless one like this, just use either of the clean workarounds and move on. \$\endgroup\$ – Brian Drummond Jan 22 '18 at 12:37
  • \$\begingroup\$ IEEE Std 1076-2008 6.5.7 Association lists, 6.5.7.1 paragraph 18 - It is an error if an actual of open is associated with a formal interface object that is associated individually. An actual of open counts as the single association allowed for the corresponding formal interface object, but does not supply a constant, signal, or variable (as is appropriate to the object class of the formal) to the formal. Not just Vivado, it allows the use of a default expression for the formal. \$\endgroup\$ – user8352 Jan 22 '18 at 16:07
    \$\begingroup\$ @BrianDrummond All synth tools have some quirks. Yes, but this rule originates in the VHDL LRM. We'll remove it in the next LRM release :). \$\endgroup\$ – Paebbels Jan 22 '18 at 17:50
